75 trailing arms bushing ?
Old 01-26-2012, 08:49 PM
oledave60
oledave60's Avatar
Default 75 trailing arms bushing ?
I am pretty new to Corvettes, but not cars. Today I removed all my rear suspension and all of the bushings need to be replaced. I have searched and read everything I could find, but still confused. I have found three different types of bushings for the trailing arm. One is rubber which requires a special tool, one is Polyurethane which comes with the tool and one from Energy Suspension that requires no tool.
which is is best and will they all work if installed properly?
New to forum,. but have gained much from the search. Thanks, Dave.
Old 01-26-2012, 09:08 PM
tracdogg2
tracdogg2's Avatar
Only the rubber ones work correctly. You're only about an hour drive from me. Let me know if I can help you out.
Mike
Old 01-26-2012, 09:40 PM
oledave60
oledave60's Avatar
Thanks for the quick reply. I just don't want to spend $90 for the tool and $45 for the part. Thanks, Dave.
Old 01-26-2012, 11:26 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We will not install poly bushings in our shop on the trailing arms.
We use a different tool then what we sell, but we do this quite often vs. the one, two or four times a customer may use it. But if you look at the tool on our site, you'll get an idea of how it works.
Old 01-27-2012, 10:14 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Poly bushings do not allow the T/A to flex with camber changes as the arms move up and down. Rubber was in there from the factory and has lasted....how many years? Why change that now?
Old 01-27-2012, 10:23 AM
Mike Ward
Mike Ward's Avatar
Another thumbs up for Ernie and the crew!
To 75 trailing arms bushing ?
Quick Reply: 75 trailing arms bushing ?
