Compression Test with TI
Need to run a compression test and have the original TI. Can I pull the coil/dist cap wire and crank the motor like I would on a car without TI? I know very little about TI and don't want to damage anything.
I read the chassis service manual and there are no special instructions for TI.
pull the wire out of the cap end and ground it
Good deal, thank you
Can I test compression on a cold motor? Does it have to be up to operating temp? Chassis service manual states 150psi per cylinder.
yes, you can, you will be more concerned with variation between cylinders.
