Has anyone installed a Unisteer Rack and pinion setup?
My C3 does not currently have powers steering, and the steering is a little jerky. I am seriously considering going to a Unisteer rack and pinion setup and adding their power steering pump with the remote fluid tank.
Just wanted to see if anyone had installed this system and how it compares to Steeroids or VBP setups.
Thanks,
Shotgunvet
Thanks,
Shotgunvet
Alternative?
G'day,
Have you looked at the Borgeson integral power steering box? I have one in my '74 and it made the world of difference. It's designed to bolt right in with no modifications apart from a slight shortening of the steering shaft. This is easy to do as '68-on Vettes had collapsible columns.
If you have access to a hoist and are a competent with hand tools, you can knock the job over in a few hours. Call Jeff or Gil at Borgeson on 1-860-482-8283. Check out their website at www.borgeson.com .
Overall, the Borgeson kit will cost about half of the average R&P kit, have a better turning circle, and no bump steer, as it uses all of the factory steering linkages, even the Pitman arm.
Regards from Down Under.
ausiiejohn
ausiiejohn
I think that if I was looking to add PS to a C3 I would look at the Borgeson system for ease of installation and cost. It is true that the Borgeson system is still recirculating ball technology but that system can be very good when setup correctly with no play in the steering. I have a factory/OEM steering box that was custom blueprinted/rebuilt by Gary Ramadei for very little money and uses all factory components and my steering has ZERO play in it BUT still has the factory steering ratio of 16:1. To me the real advantage of the Borgeson unit is the ease of the conversion and probably more importantly, that the steering box uses a 12.7:1 steering ratio, although it may be a tad too quick for a C3 suspension on the street...just me.
I have the Borgeson unit, it is responsive, tight, quick and after 25k miles I feel it was the best upgrade. GM should have used it on the C2's and C3's.
You must have a well serviced front and rear suspension. Installing a Borgeson or any rack and pinion unit will not get you to a C7.
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19
I don't remember seeing anyone here install one of those systems but do remember someone installing a R&P with that type cradle but think it was a Flaming River system. There was a good bit of modifications to get the Flaming River system to work as they wanted it to. I'm not much help with the review of the Unisteer unit but I can say I did a DIY R&P install on my car and its been one of the best mods I've done. Just about every sports car on the road today has R&P, it is very hard to beat the feel of a well setup R&P.
Neal
Neal
