Caliper Question
Caliper Question
Hello everyone. I am new to the site and have a question on brake calipers for my 72.
I am replacing all brake components and am deciding on what calipers to buy. I know the problems associated with the split 4 piston calipers so I want to buy ones that I won't have issues with. Do you recommend stainless steel calipers only or will standard calipers be just fine?
Thanks in advance!
Thanks in advance!
I have had SS calipers on my 78 since 1985 with OEM O ring seals and have never had a problem with the calipers leaking on a car that sits most of the time. I would not recommend non stainless steel sleeved calipers since the bores will pit over time and the calipers will leak. I do not think that the lip seal calipers are necessary. Just change the brakes fluid every 3 years or so and you will be fine. Hope that helps!
If your calipers are stainless steel sleaved then I would just clean, paint, and rebuild with an O-ring kit.
Here is a full O-ring kit for $150 shipped with new bolts and bleeders.
http://fixvetteparts.com/cgi-bin/online/storepro.php
Controversial as this subject always is, my suggestion would be stainless sleeved calipers and DOT 5 silicone fluid. Just about as 'set it and forget it' as it gets.
If you've got a bunch of burning a hole in your pocket, Wilwood makes aluminum replacement calipers that are lighter weight than OEM.
Received 3,139 Likes
Getting pretty hard to find a set of calipers that haven't been sleeved yet anyway.
I changed mine over to O-Rings a few years ago, completely solved the air-pumping and also the weeping problems. That being said, now that my rotors are running properly the air-pump issue is a mute point.
Mooser
Just bought a complete set of calipers form Stainless Sterl Brake Corporation. Didn't realize how bad the original pistons were until I took them off. Holy cow!
I had no problem instaling or bleeding the new brakes because SSBC provided very good literature with the system.
Thanks for all the feedback. I think I'll definitely go with the stainless steel. The current calipers are original to the car so they are not sleeved already.
Thanks again!
Thanks again!
The caliper is not stainless steel but there is a SS sleave inside where the piston is. If that is there then you can rebuild.
I just popped off the seals and removed the calipers. I've rebuilt pistons before but this is kind of new to me...How can I tell if they're stainless steel sleeved or not? I'm trying to post pictures but am having some trouble.
Here are some pistures that show what it looks like...
http://temp.corvetteforum.net/c3/joe...ructions.shtml
The SS sleave stands out once you know what you are looking for. When I took mine apart it was pretty clear mine are SS sleaved. So 1 4 wheel O-ring kit from above is on its way for my car. That and new rotors and Performance friction brakes pads.
I highly recommend O-ring seals if your calipers have stainless steel inserts.
Rick B.
Thanks for all the info. It looks lik my calipers are in fact SS sleeved. I'll go with an o-ring rebuild kit similar to what Marlin is doing. Thanks again for all the help!
