sealing differential gasket
What do you recommend to seal the differential gasket. I tried it dry , on my spare original differential and it leaks. I'm use to gaskets actually sealing and not needing "glue" to seal something.
I always put a small bead of RTV on the cover around the whole thing and surrounding the bolt holes, and then I apply the gasket to the cover and let it set for 5 minutes. Then mount it up and torque it to spec (I always do 100 in lbs). Always worked for me on every diff I have done.
Will
Will
Primoz (03-31-2022)
I put a thin layer of grease on both sides of the gasket it holds it in place and I never had them leak. I think one of the GM service manuals said to do it that way.
Primoz (03-20-2022)
Will
Will
Permatex High Tack spray on gasket sealer on the stock paper gasket. Spray both sides of the gasket, let it dry for 5-10 minutes, and assemble. One of the few things I seem to be able to assemble without leaking. Now if I could just get my oil pan as tight...
