Motor Oil Wear Test Results – Caution, VERY long
Old 03-19-2012, 03:09 PM
540 RAT
540 RAT's Avatar
Default Motor Oil Wear Test Results – Caution, VERY long
I think folks would generally agree that the most important thing a motor oil does, is prevent metal to metal contact. Everything else it does comes after that. Liquid oil is incompressible, no matter what the viscosity. So, in the places and conditions inside an engine where you have enough flow between parts to maintain a presence of liquid oil without it being squeezed away, all oils will offer similar protection in preventing metal to metal contact.
But, under extreme loading and/or heating conditions, as well as at flat tappet interfaces, distributor gear interfaces (particularly those with high volume oil pumps), BBC lifter bore primary thrust surfaces (due to tilted pushrods and often offset pushrod seats in the lifters, along with high spring pressures), and cold start-up where oil has run off, to name just a few examples, you can be left with only a very thin “film of oil” to prevent metal to metal contact, rather than enough flow to have a presence of liquid oil.
In these cases, an oil’s “load carrying capacity/film strength” is all-important to prevent wear. And in this regard, oils vary greatly. But finding this data for comparison is nearly impossible because most oil companies do not publish this type of info. And when you can on occasion, come up with some data, you never know if you can trust its accuracy because it will typically be advertising based.
I consider “load carrying capacity/film strength” to be the first thing to consider when choosing a motor oil to run. Detergent/dispersant levels for anti-deposit buildup/anti-sludge, TBN acid neutralizer levels, anti-foaming agent levels, and NOACK volatility percentages, etc, etc, all come after that.
So, I bought an oil “load carrying capacity/film strength” tester. This gives me the capability to test and compare various oils head to head, using the exact same test equipment and the exact same test procedure. That way I’d know the truth first hand. The testing was performed in Southern California during February and March 2012.
As far as I know, I’m the only one who has ever done such a wide ranging motor oil wear test. I went to all this trouble because I wanted to “KNOW” how good various oils are, rather than have to essentially guess. I really only did this testing for my own knowledge, and to share it with a handful of car buddies. But a few of those car buddies talked me into posting the info on some of the Forums, so that everyone could get a chance to see all the data. So, the test results are shown below, for those who might like to see them.
I’ll make it perfectly clear right up front. My testing was not done inside a running engine. I tested 44 different oils, and testing that many oils in a running engine was simply not practical, not to mention that there would be too many variables to have a true apples to apples comparison. All my testing was done with the oil tester. So, for those who put no value on data gathered from “Lab” testing, feel free to close out now, and go on to the next topic. For everyone else, read on.
My tester spins a test ring bathed in oil at 456 rpm (7.6 rev/sec), and a test specimen is “gently” brought down into contact with the spinning ring. A load is then “gently” applied to the test specimen and is “gradually” increased, so as not to suddenly punch through the oil film, and also to allow the zinc a bit of time to get hot and become effective.
At the conclusion of each 30 second test, the wear scar that is generated, is carefully measured with the aid of a magnifying glass to maximize accuracy. Then the psi that the oil supported, is calculated, which gives the value of its “load carrying capacity/film strength”. All the oils are of course subjected to the exact same test procedure, so they all have the same opportunity to perform as well as they can.
NOTE: The test results are intended to enlighten and inform, not to offend. And they were generated without bias towards any particular brand or viscosity. To prove that there was no bias here, my long time “oil of choice” Royal Purple, did not show up all that well. And I did not hesitate to show that. For better or worse, the numbers simply are what they are, and speak for themselves.
I have a copy of the official ASTM D 2782, the Standard Test Method for Measurement of Extreme-Pressure Properties of Lubricating Fluids (Timken Method). And for the record, ASTM D 2509, is the Standard Test Method for Measurement of Load-Carrying Capacity of Lubricating Grease (Timken Method). They are NOT the same test spec.
The ASTM D 2782 calls for testing the oil at 100*F, yes 100*F, NOT 100*C. Testing at that temperature is completely worthless in my mind. Because that is really just a hot “room temperature”, and is not hot enough to be representative of actual oil temperatures inside a running engine. And for example, 0W30 and 10W30 are not even the same viscosity at room temperature, but they are rated the same viscosity by the time they reach 212*F (100*C). So, in order to obtain the most valid data possible, I did all the oil tests at 230*F, which has all the same hot category multi-viscosity oils at the “same” viscosity, and is representative of oil temps inside a running engine. That being the case, I did not precisely follow what I consider the useless ASTM D 2782 standard.
Note:
*** The test procedure I used was developed and refined to obtain the best possible repeatability, which ensures the most accurate test results possible. Once I made the final revision to optimize the procedure, testing began and the exact same test procedure has been used over and over again for all the following tests.
*** I used 5W30 Castrol GTX conventional oil during the entire test procedure development phase, in order to keep things consistent. During that time, I tested it both HOT (230*F) and COLD (mid 60’s F). And it’s COLD “Load carrying capacity/Film strength” was about “TWICE” as high as its HOT capability. So, the hotter and thinner the oil, the lower its “Load carrying capacity/Film strength”.
*** The testing here only evaluates “Load carrying capacity/Film strength”, but does NOT test an oil’s slipperiness/friction reducing qualities. Load carrying capacity and slipperiness do NOT necessarily go hand in hand. For example, if we were to fill our engines with thick old school STP Oil Treatment, we’d have much higher “load carrying capacity/film strength”, but the HP would plummet due to all the extra viscous drag. Therefore, the testing here does NOT provide any information regarding HP increasing capabilities. But in the future, I do plan on doing a separate oil test on the “slipperiness/friction reducing qualities” of each of the oils tested below. So, stay tuned for that.
*** I was able to directly compare 20 wt type oils, 30 wt type oils, 40 wt type oils and 50 wt type oils because even at 230*F, all the oils stayed on the spinning test ring nicely without flinging off. Therefore, no viscosity had any advantage over another.
A few overview highlights of the results:
*** The High Performance and Racing oils did NOT dominate all the top ranking positions as expected. In fact, contrary to popular belief in the Hotrod and Racing world, simply having high levels of zinc/phos was absolutely NOT a guarantee of high “load carrying capacity/film strength”. Some high zinc/phos oils had excellent test results, while other high zinc/phos oils had only fair test results.
*** This testing has clearly shown that a particular oil’s “load carrying capacity/film strength”, is NOT determined just by its zinc/phos levels, but rather, it is determined by the oil and its additive package “as a whole”. So, if people choose an oil strictly based on its zinc/phos levels, they could easily end up having a “LOT LESS” protection than they think they have.
*** This testing has clearly shown that an oil’s viscosity is also absolutely NOT an indicator of its “load carrying capacity/film strength”. Among the 44 oils tested here, 50 wt type oils ranked from 6th to 40th, 30 wt type oils ranked from 1st to 44th, and 20 wt type oils ranked from 10th to 35st. So again, an oil’s “load carrying capacity/film strength” is determined by the oil and its additive package “as a whole”, nothing else.
*** This testing has clearly shown that you simply CANNOT PREDICT an oil’s “load carrying capacity/film strength” by looking at its specs or its viscosity. You can only determine that capability by performing some type of actual wear testing, as I’ve done here. But, there are of course other wear test methods that can be used as well, such as the 4 Ball Wear Test which is somewhat popular in the oil industry. Though I have only seen Amsoil list results from that type of wear testing. My tester and the 4 Ball wear tester are in no way attempting to duplicate engine internals. Instead, they are designed to test oils directly against each other in a controlled and repeatable manner.
*** The latest “LOW” zinc/phos API certified oils, both synthetic and conventional, performed WAY better than expected. In fact, they are so good that their capability has surpassed most of the traditional high zinc/phos High Performance and Racing oils.
*** “Low cost” conventional API certified oils performed WAY better than expected.
*** Lucas and Valvoline Racing oils performed very well.
*** Royal Purple High Performance, Racing and street oils generally performed below expectations.
*** Brad Penn High Performance and Racing oils performed below expectations.
*** With that said, there are no BAD oils here. Some are simply better than others in terms of “load carrying capacity/film strength”. Those that have a higher capacity, offer a higher margin of safety than those with a lower capacity.
Motor Oil Wear Test Results and Ranking
*** The higher the psi result, the higher the “Load carrying capacity/Film strength”, and the better the oil is at preventing wear.
*** All oils were tested at 230* F (representative of actual running temperature).
*** Multiple tests were performed on each oil, and those results were averaged to arrive at each oil’s final value shown below. Differences between oils of 10% or less, are not significant, and oils within that range can be considered approximately equivalent.
*** All oil bottles were thoroughly shaken before the samples were taken. This ensured that all the additive package components were distributed uniformly throughout all the oil in the bottle, and not settled to the bottom.
*** All oils are full synthetic unless otherwise specified.
*** All oils are suitable for street use unless otherwise specified.
Oil categories:
*** Over 90,000 psi = OUTSTANDING protection
*** 75,000 to 90,000 psi = GOOD protection
*** 60,000 to 75,000 psi = MODEST protection
*** Below 60,000 psi = UNACCEPTABLE protection
********** OUTSTANDING PROTECTION ************
1. 5W30 Pennzoil Ultra, API SM = 115,612 psi
I have not been able to find this oil with the latest API SN certification. The bottle says, “No leading synthetic oil provides better wear protection”. For once, a product’s hype turns out to be true.
zinc = 806 ppm
phos = 812 ppm
moly = 66 ppm
2. 10W30 Lucas Racing Only = 106,505 psi
zinc = 2642 ppm
phos = 3489 ppm
moly = 1764 ppm
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
3. 5W30 Mobil 1, API SN = 105,875 psi
zinc = 801 ppm
phos = 842 ppm
moly = 112 ppm
4. 0W30 Amsoil Signature Series 25,000 miles, API SN = 105,008 psi
zinc = 824 ppm
phos = 960 ppm
moly = 161 ppm
******* 10% below number 1 = 104,051 psi ********
5. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phos = 1518 ppm
moly = 784 ppm
6. 5W50 Motorcraft, API SN = 103,517 psi
zinc = 606 ppm
phos = 742 ppm
moly = 28 ppm
7. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phos = 1544 ppm
moly = 3 ppm
8. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phos = 1112 ppm
moly = 162 ppm
9. 5W30 Chevron Supreme conventional, API SN = 100,011 psi
This one only costs $4.29 per quart.
zinc = TBD
phos = TBD
moly = TBD
10. 5W20 Castrol Edge with Titanium, API SN = 99,983 psi
zinc = TBD
phos = TBD
moly = TBD
titanium = TBD
11. 20W50 Castrol GTX conventional, API SN = 96,514 psi
zinc = 610 ppm
phos = 754 ppm
moly = 94 ppm
12. 30 wt Red Line Race Oil = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
moly = 1235 ppm
13. 0W20 Mobil 1 Advanced Fuel Economy, API SN = 96,364 psi
zinc = TBD
phos = TBD
moly = TBD
14. 5W30 Quaker State Ultimate Durability, API SN = 95,920 psi
zinc = 877 ppm
phos = 921 ppm
moly = 72 ppm
15. 5W30 Castrol Edge with Titanium, API SN = 95,717 psi
zinc = 818 ppm
phos = 883 ppm
moly = 90 ppm
titanium = 44 ppm
16. 10W30 Joe Gibbs XP3 Racing Oil = 95,543 psi
zinc = 743 ppm
phos = 802 ppm
moly = 1125 ppm
17. 5W20 Castrol GTX conventional, API SN = 95,543 psi
zinc = TBD
phos = TBD
moly = TBD
NOTE: Oil numbers 16 and 17 were tested weeks apart, but due to the similarities in their wear scar sizes, their averages ended up the same.
18. 5W30 Castrol GTX conventional, API SN = 95,392 psi
zinc = TBD
phos = TBD
moly = TBD
19. 10W30 Amsoil Z-Rod Oil = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
moly = 52 ppm
20. 5W30 Valvoline SynPower, API SN = 94,942 psi
zinc = 969 ppm
phos = 761 ppm
moly = 0 ppm
21. 5W30 Valvoline Premium Conventional, API SN = 94,744 psi
zinc = TBD
phos = TBD
moly = TBD
22. 5W20 Mobil 1, API SN = 94,663 psi
zinc = TBD
phos = TBD
moly = TBD
23. 5W20 Valvoline SynPower, API SN = 94,460 psi
zinc = TBD
phos = TBD
moly = TBD
******** 20% below number 1 = 92,490 psi ********
24. 5W30 Lucas conventional, API SN = 92,073 psi
zinc = TBD
phos = TBD
moly = TBD
25. 5W30 O'Reilly (house brand) conventional, API SN = 91,433 psi
This one only costs $3.99 per quart.
zinc = TBD
phos = TBD
moly = TBD
26. 5W30 Red Line, API SN = 91,028 psi
zinc = TBD
phos = TBD
moly = TBD
27. 5W20 Royal Purple API SN = 90,434 psi
zinc = TBD
phos = TBD
moly = TBD
28. 5W20 Valvoline Premium Conventional, API SN = 90,144 psi
zinc = TBD
phos = TBD
moly = TBD
************ GOOD PROTECTION **********
29. 30 wt Castrol Heavy Duty conventional, API SM = 88,089
zinc = TBD
phos = TBD
moly = TBD
30. 10W30 Joe Gibbs HR4 Hotrod Oil = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
moly = 24 ppm
31. 5W20 Pennzoil Ultra, API SM = 86,034 psi
zinc = TBD
phos = TBD
moly = TBD
32. 5W30 Royal Purple API SN = 84,009 psi
zinc = 942 ppm
phos = 817 ppm
moly = 0 ppm
33. 20W50 Royal Purple API SN = 83,487 psi
zinc = 588 ppm
phos = 697 ppm
moly = 0 ppm
34. 5W30 Mobil 1 Extended Performance 15,000 mile, API SN = 83,263 psi
zinc = 890 ppm
phos = 819 ppm
moly = 104 ppm
35. 0W20 Castrol Edge with Titanium, API SN = 82,867 psi
zinc = TBD
phos = TBD
moly = TBD
******** 30% below number 1 = 80,928 psi ********
**************** MODEST PROTECTION ************
36. 5W30 Royal Purple XPR (Extreme Performance Racing) = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
moly = 204 ppm
NOTE: This particular bottle of oil was just opened, but was out of a 3 ½ year old case.
37. Brad Penn, Penn Grade 1 Nitro 70 Racing Oil (semi-synthetic) = 72,003 psi
zinc = TBD
phos = TBD
moly = TBD
38. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,377 psi
zinc = 1621 ppm
phos = 1437 ppm
moly = 0 ppm
39. 10W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,206 psi
zinc = 1557 ppm
phos = 1651 ppm
moly = 3 ppm
40. 15W50 Mobil 1, API SN = 70,235 psi
zinc = 1,133 ppm
phos = 1,168 ppm
moly = 83 ppm
******** 40% below number 1 = 69,367 psi ********
41. 5W30 Motorcraft, API SN = 68,782 psi
zinc = 796 ppm
phos = 830 ppm
moly = 75 ppm
42. 10W30 Royal Purple HPS (High Performance Street) = 66,211 psi
zinc = 1774 ppm
phos = 1347 ppm
moly = 189 ppm
43. 10W40 Valvoline 4 Stroke Motorcycle Oil conventional, API SJ = 65,553 psi
zinc = 1154 ppm
phos = 1075 ppm
moly = 0 ppm
44. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi
zinc = TBD
phos = TBD
moly = TBD
******** 50% below number 1 = 57,806 psi ********
Summary:
Readers can of course do whatever they want with these results. But for me, seeing is believing. The smallest wear scars created by the best oils, were quite impressive. So, now I’ll be choosing oils for my Hotrods and daily drivers from the OUTSTANDING PROTECTION category, in order to have the highest level of protection. There are plenty of different oils in this category, 28 of the 44 to be exact, and they all have 90,000 psi or higher capability. After reading this report, you may never think about motor oil the same way again.
The following 4 users liked this post by 540 RAT:
CB-24 (03-05-2020), HandOverFist (08-19-2022), Mareque (06-27-2022), RWBaker (03-24-2023)
Old 03-19-2012, 03:43 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by 540 RAT
........................ So, for those who put no value on data gathered from “Lab” testing, feel free to close out now, and go on to the next topic. For everyone else, read on.
I'm one who appreciates seeing the data. My thanks for all your work on this.
Old 03-19-2012, 04:37 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
I too appreciate to work put into this. I agree with the theory that film strength is the best indicator of the oils ability to protect against metal to metal contact, the testing you have done is valid and comprehesive and that ZDDP levels are not the only thing you need to look at when selecting an oil. Your testing is a great resource if you are running a high horsepower, roller cammed engine.
The one point that you have overlooked is the fact that the loading at a flat tappet cam lobe/ lifter interface is over 200,000 PSI in a stock engine and can increase to over 300,000 psi when fast ramps, high lift, heavy springs and heavy valvetrains are used. At this point you are well beyond the maximum film strength of 115,000 psi you found and film strength will no longer protect these parts from metal to metal contact. This is when ZDDP comes into play. It deposits a sacrificial layer when subjected to heat and loading directly on the parts that see this loading not ecountered by any other part in the engine. A stock flat tappet, hydraulic lifter small block needs less zinc and phosphorous than a flat tappet, solid lifter, high lift big block but both need a minimum of 1000 PPM Phos. Zinc and phosphorous levels can not be ignored or discounted when using a flat tappet cam. I would suggest to those with a flat tappet cam that really care about the protection their oil provides to use your chart as a guide and choose an oil with the highest film strength that also has sufficiant ZDDP levels for the cams ramp, lift, lifters, spring pressures and rpm their engine uses.
Edit: Also avoid High detergent/dispersant oils like diesel oils, They compete for the same space as ZDDP and reduce the effectivness of it.
Old 03-19-2012, 04:40 PM
Manuel Azevedo
Manuel Azevedo's Avatar
While I understand and appreciate what you are trying to do, the data means not much. When an oil is run in an engine it is subject to much much more than a given load. How it relates to the acids created from combustion is a major influence on the oil as well as different types of dispersant's to name but a few. Your type of tests would be just fine if an engine did not run on any kind of fuel and did not have contaminates and metals in it produced from a running engine. It takes much testing in real running engines to produce any kind of meaningful comparisons.
Old 03-19-2012, 04:57 PM
rponfick
rponfick's Avatar
Great info. Thanks for your efforts.
Ralph
Old 03-19-2012, 05:20 PM
iokepakai
iokepakai's Avatar
Just rcvd some Amsoil Zrod.Good to know it's up there on the list & has high levels of zinc,phos,& moly.Thanks for taking the time to compare all the different oils. Just a thought would it be better to add the ZDDP Plus to a good oil or run something like Zrod which has the zinc blended in?? Aloha's
Old 03-19-2012, 05:36 PM
632C2
Support Corvetteforum!
632C2's Avatar
Rick, this is quite a project you just completed! You deserve kudos for the effort and expense you went to - and the fact that you are sharing! I for one am quite impressed and saddened at the same time. I've got 2 cases of RP XPR 5w-30 sitting in my garage thinking it was the best thing since sliced bread.
I am going to have to think about this...
Steve
Old 03-19-2012, 06:53 PM
63mako
63mako's Avatar
Additive clash results from mixing different additive packages that may or may not work well together. Every oil manufacturer recommends not to do this. You have a good choice in your engine.
540 Rat, I was very suprised at how well some of the conventional oils tested considering most information I have to date show that synthetics are generally considered to have over 5x the film strength of conventional oils. Is it possible that friction reducers and antiwear additives could reduce the scar on your test ring skewing the results? Not argueing the test or method just wondering. As you know, I have recommended Amsoil AMO 10W-40 for quite some time. Did you test it?
Old 03-19-2012, 08:17 PM
ltblue79
ltblue79's Avatar
Thank you so much for sharing this info! This is truly a must read for everyone. Im glad I got talked into running Amsoil ZRod last year since it tested so well.
Old 03-19-2012, 08:58 PM
Tim H
Tim H's Avatar
So basically none of them have flat tappet cam protection so run your favorite brand and an additive.
Mines Castrol 10W40 and a bottle of Comp Cams break in additive.
CheezMoe
CheezMoe's Avatar
St. Jude Donor '11-'12-'13,'19-'20
Thanks for this data! I've been using off the self street VR-1 10W-30 with my CompXE flat tappet since it was installed four years ago! nice to see data that supports rational and available choices!
Old 03-19-2012, 09:04 PM
iokepakai
iokepakai's Avatar
Good info! Looks like Zrod oil it is.....Much Mahalo's
Old 03-19-2012, 10:44 PM
SmokinBBC
SmokinBBC's Avatar
Kudos for the tests!
I ran accross this article a while back. Except for RP, oils tested are different. i think you did the same test. The PSI for RP is much higher in the article. I think the difference in the tests is that you heated the Oil?
http://www.animegame.com/cars/Oil%20Tests.pdf
Old 03-19-2012, 10:59 PM
63mako
63mako's Avatar
No, that is not what it says at all, Did you read the list? There are a few oils on this list with high film strength (Excellent Protection) that also have plenty of ZDDP for any level of ZDDP protection you may need and designed for street use. Might want to check the results again. Why would you use a break in additive in an engine that was already broken in? Break in additives are specifically designed for very short term use to seat rings and break in cams then drain it.
Old 03-19-2012, 11:24 PM
63mako
63mako's Avatar
The street VR1 is not listed in the test, Only the racing VR1 is listed.
Old 03-20-2012, 02:56 PM
540 RAT
540 RAT's Avatar
You should reread my data. Some high zinc/phos oils such as Lucas and Valvoline Racing oils tested very well. Other high zinc/phos high performance and racing oils such as Royal Purple and Brad Penn did not test very well.
So, like I said, high levels of zinc/phos are absolutely no guarantee of the best wear protection, as indicated by the differnces in those oils. And you simply cannot determine how good an oil is regarding wear protection, by looking at its spec sheet and its zinc/phos levels. Things are just not that simple. The 5W30 Pennzoil Ultra, API SM will kick butt on every other oil in the test, with or without high levels of zinc/phos.
Regarding your 200,00 and 300,000 psi numbers, let me make something perfectly clear right now. You CANNOT compare the test's psi numbers with your psi numbers. The tester does not reproduce engine internal parts. It is intended for oil to oil comparison testing only. Trying to compare your psi numbers to the test's psi numbers, is comparing apples to oranges. The test's psi numbers are generated from a test specimen simply being pressed down onto a spinning ring, that's it. But at the flat tappet interface in a running engine, the parts are being subjected to a combination of pushing, shearing, twisting and sliding forces. They are NOT the same and are NOT intended to be the same. Trying to compare the two would almost be like comparing a Corvette to a vacuum cleaner. It just makes no sense. Keep things in context here.
Old 03-20-2012, 02:58 PM
540 RAT
540 RAT's Avatar
Not all testing is practical in a running engine, even though in a perfect world that would be ideal. Try testing 44 different oils in an engine, with the "exact same" conditions every time, and doing all that in a timely manner. It wouldn't be doable, would it? And wouldn't you like to at least start out with an oil that "Lab tests" well, rather than one that did not? For the record, acids are not an issue if you have sufficient TBN acid neutralizer levels in the oil.
To Motor Oil Wear Test Results – Caution, VERY long
Old 03-20-2012, 03:03 PM
540 RAT
540 RAT's Avatar
The whole point of this testing was to see how hot oils perform with their friction reducers and their antiwear additives present, along with everything else in the oil. They don't skew the results, they DETERMINE the results.
Old 03-20-2012, 03:09 PM
540 RAT
540 RAT's Avatar
Royal Purple USA told me that their Australian Distributor sponsored that Magazine oil test. So, was there a conflict of interest there, with regard to how well the Royal Purple oil did? Decide for yourself. And yes they test the oil cold, which is useless, not to mention that it will show the resulting numbers around twice what they are when hot. I tested mine hot, and I had no conflict of interest. In fact, I have run Royal Purple in everything for years, and always prompted it. But I'll choose something better, now that I've seen the test results with my own two eyes.
Old 03-20-2012, 03:15 PM
540 RAT
540 RAT's Avatar
That is NOT true. Valvoline VR1 Conventional Racing Oil in the silver bottle, and Valvoline VR1 Synthetic Racing Oil, API SL in the black bottle are both perfectly suitable for street use. They have everything in there that you need.
Quick Reply: Motor Oil Wear Test Results – Caution, VERY long
