Motor Identification ???
I have a motor I believe to be an L82...
Stamped on the block,(Rt-front)
V0410CKC
15S423395
Head casting # 333882
It has 4 bolt mains, forged crank and pushrod guide plates...
Any idea about the heads, would these be 2.02 or 1.94 valves ?
Looking for any information available for this motor.
The Old Timer II
V0410CKC
15S423395
The Old Timer II
I'm not an expert at this stuff either but from what I can decode the front pad stamp and the head casting numbers are correct but I couldn't find that engine block casting number. Maybe someone else can help with that.
Front Pad - V0410CKC = Flint Plant, April 10th, Corvette L82 / TH350
(Other possible applications were Nova, Chevelle, and Impala.)
Head Casting - 333882 - 350 / 400 - 1970 / 1980 - 1.94 / 1.50 - 76cc
The block appears to be a Corvette L82 block.
Heads and Valves
I was hoping the valves would be the larger of the choice...
We'll see, I'll have to get in there anyway to be sure all is well with the rotating assy...
It has all the right make up so far, it's been re-done once has a "Crane" stick... don't know what yet.
Bought this with an ElCamino, a project gone astray... sold the car kept the motor
Just looking for the right opportunity to put this together correctly and play...
Thanks for all the responses... really helps.
