How to remove the upper control arm bolts
Old 12-22-2012, 01:40 AM
pepegriffo
pepegriffo's Avatar
I had the same problem with the bolts spinning. I puy a few spot welds on the bolt head.Does not spin. The issue is, if the boly turns it's problem because you can't get back in there with a socket to hold it from spinning.
Quick Reply: How to remove the upper control arm bolts
