Swap TH400 for a 200-4R Question
Well, I'm thinking about swapping out the transmission in my '75 for something with overdrive. My wife doesn't like how the car sounds like it's taking off when you're on the interstate (and how she can't talk to me without yelling) and I don't like how quickly the fuel tank needle falls...
Anyway, I've been doing a lot of reading on 700-R4 vs 200-4R and have come to the conclusion that the 200-4R is less of a pain for similar gains. I was wondering if anyone that's changed to the 200-4R had to alter their u-joints or driveshaft length?
I read in a bunch of forums that the driveshaft only would have to be modified for the 700-4R but when I talked with a rep from Bowtie Overdrive, he thought it might have to be.
Also wondering if it's worth swapping out my crossmember for Bowtie's custom bolt-on one since I'm changing from the TH400 where the mounts are very close?
I put a 200-4r in my 75 where the TH400 was. The drive shaft does not need to be modified. You will need a slip yoke from a th350 vette and probably a 1310 to 1330 conversion u-joint(commonly found at all parts stores) No need to change cross members, the stock one will work, just have to slightly file out or elongate the bolt holes for the trans mount.
Bowtie is asking $110 for a new yoke and it looks like the Corvette catalogs want something like $130-160... Seems like getting the yoke from them is decent deal.
Thanks for the info!
I have the 200R4 also....no need to modify the driveshaft or change out the crossmember....as mentioned earlier you will need a conversion u-joint(can dig the number up for you later), BTO will get you set up with whatever you need
It's a good idea to have the driveshaft balanced also while you have it out
I also changed my TH400 to the 200-4R. I got everything from BTO. Well worth it.
The only part I could not find was the bracket that the steering lock cable attaches to the trans with. I had to make one. If you need one I can get you the drawings. I made several at the time but I do not have the time to make them any more.
Good luck.
Good luck.
http://forums.corvetteforum.com/c3-t...e-a-200r4.html
http://forums.corvetteforum.com/c3-t...too-short.html
drop down to post 46
http://forums.corvetteforum.com/c3-g...rogress-3.html
Hammadown
Hammadown
What is your diff gear? If it's pretty steep, like a 3.70 or higher (numerically) the 200 would definitely be the way to go. If you have a highway gear, you might want to take another look at the 700 with it's low first gear. You said the better half doesn't like how it winds out on the highway, so you may have a pretty steep gear in there, '75 'vettes could be ordered with a diff gear anywhere from 2.73 to 4.11 (The last year 4.11 gears were offered on the Corvette)
http://corvettec3.ca/axle.htm
Keep the shiny side up!
Scott
Scott
With relevance to the OP - how much difference will be noticed between the 700 and the 200?
For my situation - how much more pain will the 700 be to install vs the 200? I have read threads on each; anyone done both?
This might be something to consider...I swapped from a th350 to the 200. If the 400 cross-member is like the 350 where the exhaust goes through tubes you may have clearance issues where the shape of the 200 pan partially blocks them. I got a BTO cross-member and it fit perfectly making room for the exhaust. Well worth it.
Arggg! I am in the same boat but I have an '80 with the TH350c. Everytime I think I am ready to order a 200r4 I see something like this. I don't mind the launch through 1st and 2nd with the TH350+ 3.07 diff the way it is now.
For the OP: I believe you can use your existing crosssmember, but an aftermarket crossmember will be lighter, if that is something that matters to you. I don't know anything about the exhaust issue posted above, one way or the other, but it sounds legit, so that may be another reason to use an aftermarket crossmember.
Scott
Hey thanks for all the great responses!
So my rear differential ratio is 3.08 (confirmed using the numbers and I'm fairly certain it has never been rebuilt). I originally had chosen to go with the 700-R4 because it's basically "the go-to" for hot rods. After reading how much easier the swap for a 200-4R was from a TH400 and the "smoother transitions", I was sold on it. Not to mention the local transmission shop thought it would be the better bet for me. The transmission guy said what I really should get is the TH400 with an overdrive (can't remember the model number) which unfortunately requires the tunnel to be modified for the transmission to fit. Not up for that, so 200-4R it is...
Anyway, I found a guy in town that's going to rebuild my differential with a 3.55 ratio. My mechanic agreed that 3.55 would be appropriate for my new engine so I can get good starts and still have a good experience on the highway.
As far as my questions go, I'm definitely going with the Bowtie Overdrive 200-4R and I'm going to use my stock crossmember. The rep at Bowtie thought their crossmember would reduce the weight by only about 10 lbs. That is fairly significant, but I'm not drag racing so 10 lbs is not a big deal to me. I'll just save the $190 for my differential rebuild. As for the exhaust. I don't have to worry about it. I have side pipes with hooker headers. Those exhaust hole sit empty (the Bowtie crossmember would make it look cleaner... hmm...).
You can get the Yoke at most auto parts stores. can't remember which one i went to but it cost around $35 5 yrs ago.
