Need Advice - Oil (film) Leak
I'm getting an oil film on our aluminum intake around the distributor. I used the paper style gasket that came in the engine rebuild kit.
The leak isn't really a "leak" as in dripping etc. Just a slight film on the aluminum which is frustrating because I had it bead blasted and it DID look like brand new
How can I eliminate this leak? Part 2 of the question is what can I use to clean the oil film up when I take care of this leak? Carb cleaner? Brake Kleen? Something along that line maybe?
Thanks in advance for any advice on this,
Adam
Adam
Do you have a working PCV system? Maybe you have oil film on everything, but only notice it on the stuff you just cleaned. If it really is coming from the base of the distributor, you may need two gaskets under it (or an extra-thick one).
Hi 7T1vette,
It's just at the distributor. Motor is brand new and very clean everywhere else. I do have a PCV as well. I guess I could double up the gasket - just seems odd that I'm getting oil film there. I didn't know they made a thicker gasket. Can also check into that.
Thanks,
Adam
Thanks,
Adam
Brake cleaner dries without residue and is not quite as nasty as carb cleaner. Still protect any paint from excess. It doesn't instantly melt paint, but won't do it any favors either.
Thanks 70Speedray,
Adam
Test for oil pump shaft clearance, you might not be seating correctly now.
Should be a crankcase pressure problem as mentioned about the pcv, but sometimes the dist and intake don't mate square and in severe cases i have used a thin oring instead of the gasket.
It might also be a leak at the rear of the intake manifold (sealing joint between the intake manifold and rear wall of engine block).
Try Greased Lighening or Simple Green and a paper towel or shop rag. Do this 2-3 times and it should take up that oil but leave the paint and aluminum as is.
Haven't heard of Greased Lighting. I'll look for that the next time I run to the store. Don't know why I didn't think of Simple Green - good stuff.
Thanks for the responses guys!
Adam
Adam
sometimes if they dont seat properly you need to add a small nylon shim under the distributor to make them seat better. i wonder if yours was right on the border of needing that and you didnt notice? did you seal or paint the intake in any way? acetone on a rag would clean up oil but be careful if that you dont melt any paint or sealer that you put on the intake. i usally paint or seal the raw aluminum so it doesnt stain
Hello Bob,
I didn't put anything on the intake after the bead blasting. I like the idea of a thin nylon shim. That would seem like a good idea compared to a paper type gasket. Twisting the distributor to set the timing always seems like a good way to tear or at least gouge up a paper gasket.
It seems to seat well against the intake, but as we all know, oil will find any way it can to spread through the smallest of spaces. Hopefully, I can get it cleaned up well and it won't be noticeable. This isn't a show car, but I worked really hard to make the motor look good and would like it to stay that way as long as possible.
Adam
Adam
