Borgeson System & Wheel Alignment
So I have the Borgeson box/system installed and I need to get a 4 wheel alignment done. I'm assuming I should be using standard wheel alignment specs?? This will be for street driving not the track.
My instructions recommend increasing caster to 3-4 degrees positive. I believe it is to make it return to center. I put the kit on about a month ago but I have"nt had it on the ground yet. I"ve been waiting for semi-coilovers that I keep hearing will be in next week for the past few weeks. Are you guys going to the inner holes on the tie rods?
