TPI swap: Upper rad hose?
Old 05-13-2012, 03:23 PM
moonsteel
Holley HP EFI w/TPI
Support Corvetteforum!
moonsteel's Avatar
Default TPI swap: Upper rad hose?
I tried a 1990 Corvette upper rad hose, that's not gonna fit.
What are people using for an upper rad hose?
dewitts rad
Old 05-13-2012, 04:09 PM
oldalaskaman
oldalaskaman's Avatar
universal?
Old 05-13-2012, 06:17 PM
mrvette
mrvette's Avatar
I dunno what you have there, and so I have to say, you need to mix and match hoses like I did, with using a brass plumbing length of drain fixture from Lowes Despot.....and a couple extra clamps....
you will have to do what I did....find a piece of hose and a t-stat housing that faces the correct way you need route your hose....that all depends on your accessory drives...so to route hose correctly, and extend length with some fittings....it maybe cost you 30 bux, but it's done....
Old 05-13-2012, 06:56 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Do they make universal with different outlet sizes?
Old 05-13-2012, 06:58 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
I was hoping to avoid mixing and matching, if possible
My accessories are stock corvette, i just swapped the intake.
Old 05-13-2012, 07:10 PM
7t9l82
7t9l82's Avatar
i d get one of those corrugated metal hoses with the rubber ends with covers.they look good and can be made to almost any shape and length
Old 05-13-2012, 07:15 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Rad
Intake
Both
1990 Corvette hose, over top. Right size (with a trim on the intake side) if my rad had a straight outlet.
Old 05-13-2012, 07:22 PM
CWerner
CWerner's Avatar
Summit flex hose on my C2.
Old 05-13-2012, 08:23 PM
oldalaskaman
yes , any napa, etc.
Old 05-14-2012, 02:10 AM
Bangkok Dean
Bangkok Dean's Avatar
Nice looking setup. Just wondering what FI system you have?
Old 05-14-2012, 02:57 AM
oldalaskaman
http://www.ecklerscorvette.com/corve...1985-1989.html
this looks close
Old 05-14-2012, 06:02 AM
666WMD
666WMD's Avatar
Steel braided would do the job and if you don't like the chrome look you could always wrap it with something.
http://www.ebay.com/itm/BRAIDED-RACE...item2c64ce042f
http://www.ebay.com/itm/NASCAR-20AN-...item2a1d4f6295
http://www.ebay.com/itm/Spectre-Radi...item4d006a80af
Old 05-14-2012, 07:19 AM
bruced267
bruced267's Avatar
When I did my swap I used a 10* adjustable t stat housing, and the stock upper hose that had to be cut in the middle and shortened.
Street & Performance has the only one that fits under the throttle body!!!
I tried 3 until this one!
Old 05-14-2012, 09:11 AM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Originally Posted by oldalaskaman
Very close, but 1.25" both ends
Old 05-14-2012, 12:42 PM
CWerner
CWerner's Avatar
I've got a TPI MiniRam managed by an OBD1 ECU. The chip was setup during a dyno session for max performance.
I originally had the TPI setup from a 89 vette. The MiniRam was a nice upgrade from 3000 RPM upto 6000. Below 3000, they are about the same.
I've been watching this thread because I might put my old TPI on my C3.
Old 05-15-2012, 01:51 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Update, ordered a Goodyear 52020, looks like it will fit
Old 05-17-2012, 01:04 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
For future ref:
If your rad outlet is straight, 1990 Corvette Upper rad hose.
If it's curved, like mine, Goodyear 52020
Old 05-17-2012, 09:48 PM
TPI BOY
TPI BOY's Avatar
[QUOTE=
I tried 3 until this one![/QUOTE]
I used the same T stat housing worked great
To TPI swap: Upper rad hose?
Quick Reply: TPI swap: Upper rad hose?
