Heater fan switch
Old 06-10-2012, 07:38 PM
cars78md
Cruising
cars78md's Avatar
Default Heater fan switch
THE HEATER FAN SWITCH IN MY 1978 CORVETTE WORKS ON THE FIRST THREE SETTING FINE,ON THE HIGH SETTING SOMETIMES IT WORKS AND SOMETIMES IT DON"T. ANY IDEA"S.....
Old 06-10-2012, 11:18 PM
mark6669
mark6669's Avatar
Check the high blower relay on top of outside evaporator box.
Mark
Old 06-10-2012, 11:43 PM
pancake
pancake's Avatar
I had the opposite problem.. but the fix is the same. Disconnect the plug, pull the relay, and pop the cover off of it.. and take an emery cloth or fine grit sandpaper and lightly clean both sides of the contacts. You don't have to do much and it'll work just fine.
Old 06-16-2012, 06:47 PM
menardd
menardd's Avatar
Default fan speed
Had the same problem, I replace the relay still did not work highest speed other speeds work. I took the cover off of relay left wires on it touch down on contact point and the high speed worked????May be the new relay was defective??
Old 06-16-2012, 10:54 PM
mark6669
mark6669's Avatar
Check for ground on black wire on relay with volt ohm meter and for 12 volts on pink wire with fan switch on high speed ( pink is from 77 wiring diagram not sure if same in 78 but probably is).
Mark
Old 06-16-2012, 11:49 PM
dmrodco
dmrodco's Avatar
just fixed mine today it was the relay check to see if you have 12VDC on the pink wire when the switch is on high if it is then its the relay of not the fuse in line with the pink wire is bad.
To Heater fan switch
Quick Reply: Heater fan switch
