What are the major advantages in a 4 bolt vs 2 bot main
IMO....no. You'd have to be running high RPMs and a lot of HP before that became an issue.....
A 2 bolt main if fine to around 500HP....
A SBC 2 bolt is a stout little dude....no worries...
Received 1,469 Likes
Cruise-In II Veteran
As mentioned, not really necessary for milder applications, but definintely more desirable the furhter you intend on pushing things. You can always install main studs (suggest ARP or Milodon), or convert to 4-bolt with aftermarket splayed caps, so ultimately there's nothing really wrong with a good 2-bolt block.
same subject - different question
My '69 coupe has the 300 HP, 350ci engine. When I had it rebuilt I was somewhat surprised to find it is a 4 bolt main engine. I guess I assumed the 300 hp was a 2 bolt. Is there an alpha/numeric designation for the '69 300 horse engine?
Depends on the engine and what you plan on doing with it. For most applications a 2 bolt is fine. However, high hp applications, high rpms or a power adder need a 4 bolt in a sbc. I've had the main bearing caps walk on 2 bolt 400's which means you just lost the bottom end. These were street-strip engines that hit 6500 rpm with some frequency. A 350 or smaller would go more.
A BBC is almost bulletproof with a 2 bolt. Unless you really spin one of those, 7k or higher, they will be fine. Again, a power adder changes the picture.
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I feel better having then in my street car!
JIM
JIM
Many Ford engines at the race track in two bolt as well as Chevrolet. There has been debate on this topic since the 60s, as I expect will happen again in this thread. They range from cap walk to weakened upper main saddles.
Personally I feel if you run a WELL balanced internally balanced engine with in 7,000 rpms or so either will serve you well as long as there are no other issues. I would like to know the ratio of main issues to crank rod and piston issues.
Normally when you loose a main, something else took it out. Crap through the bearings as an example.
I'd bet a dirty engines have taken out more mains than the caps. Not getting out all the junk empackted in oil journals claim more mains and rods for that matter I'd guess. Jet washers don't always get it all out.
If you go to studs, then align hone, you may as well pick up a set of splayed cap billet caps since you'll be paying for an align hone anyway. You can find them used on line and at swap meets for a fair price. It's easier to align hone the used ones anyway.
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Just about to say the same thing.
Studs are great but most people think you can just swap out the main cap bolts for studs.
Same goes for swapping main caps to billet caps.
Line hone will run anywhere from $300-500.
If you are going to that expense why not go 4 bolt main?
Others may experience other mileage.
Bman
