Best BBC spark plug wires.
With the help of Lars, I recently diagnosed my engine miss to a broken spark plug wire. Car is a stock '69 L-71 BBC with stock exhaust manifolds. I am not using, and don't want to use the stock metal braided wires (don't use the radio). I ordered a custom Moroso Blue Max set (No. 72550) from Ecklers assuming they would know what fit best. Either the part number was incorrect, or the kit was made on Friday/Monday, because half the wires were too short. Also, you could not tell when the wire was correctly seated on the spark plug. The boot seemed to slide on the wire and you could not get positive engagement (or didn't know if you had).
Anybody have any good recommendations? I am sending these back.
Ralph.
Ralph.
that is the correct part number for your car, any indication that someone had previously opened the box? You can take a plier and snug the plug end connector for a tighter fit.
http://www.summitracing.com/parts/MOR-72550/
Received 3,138 Likes
I just put on a new set of Taylor 8mm Spiro-Pro with 180 deg. boots
Bought the universal kit and fitted the wires the way I needed to with stock manifolds and a modified set of Taylor vertical looms.
Can't say anything wrong with them. Have had good luck with Taylor in the past (and others, but have been using these lately)
Mooser
Mooser
I'll look into the MSD wires. I like their idea of a positive click when engaging the spark plug.
It has been suggested that you can tighten the plug clip end with pliers, but I think that is already my issue. The Moroso wires are very hard to push on the plug and tend to slide up inside the boot, to the point the boot covers the entire insulator of the plug, and will not go up any further. Almost, as if the clip was too tight to begin with. And, I have always been using the dielectric lube for ease of assembly.
What else would we have to do if everything went according to plan?
Ralph
Ralph
