Willcox Combined Video Thread!
Old 06-22-2015, 04:52 PM
  #121
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I skipped over the video for the tilt column, I don't have it quite ready. I think the quality of this video will be awesome too!
So.. instead I've added this one today. It's a quick one as well but will illustrate the proper manner to install the clutch pedal retaining clip for 1963-1981 cars... Enjoy.
Willcox
Old 07-13-2015, 10:58 PM
  #122
0Willcox Corvette
Former Vendor
Okay.. for those following I'll say SOON...
I'm almost done with the standard and tilt-tele ignition switch videos... so they will be soon.
We have one completed for the c2 guys on how to safely remove your clock hands.
We have one completed for the C4 guys on how to install the rear hatch weatherstrip.
We also have two others in the works.. C4 A pillar installation as well as a few others... Soon.
Willcox
Old 07-15-2015, 10:40 AM
  #123
0Willcox Corvette
Former Vendor
84-96 Rear hatch weatherstrip installation.
Old 07-17-2015, 11:59 AM
  #124
0Willcox Corvette
Former Vendor
Newest addition for the C4 guys:
Willcox Corvette Installing 84-96 Pre-Mounted Standard Seat Covers
Old 07-27-2015, 10:46 PM
  #125
0Willcox Corvette
Former Vendor
ttt.. Wow, we are approaching 10k views..
Old 08-01-2015, 03:05 PM
  #126
spdrcr29
spdrcr29's Avatar
Maybe I have over looked it, but do you have a video of how to test the wiper door vacuum solenoid that attaches to the back of the tachometer housing for 68-82? Would like to test mine, but just not sure which side to apply vacuum and when to apply 12v. Any help would be appreciated.
Old 08-01-2015, 07:32 PM
  #127
0Willcox Corvette
Former Vendor
I have one but it's not been posted.
The test is simple though.
The solenoid is a basic electromagnet so you can apply power or ground to either side. So power up one terminal, ground the other and the relay should click..... When it does it should block vacuum from passing from one side to the other.
When you turn the wiper switch on, ground is provided to the solenoid which instantly blocks the vacuum on the small hose side. When this happens the relay plunger falls and switched vacuum on the actuator from down to up.
If you have any other questions on this please feel free to post back.
Willcox
Old 09-09-2015, 04:50 PM
  #128
0Willcox Corvette
Former Vendor
New video for installing the 1977-1982 temperature gauge adjustable resistor is almost finished. I should have it up soon.
Willcox
Old 09-13-2015, 12:02 AM
  #129
0Willcox Corvette
Former Vendor
Old 09-21-2015, 10:57 PM
  #130
0Willcox Corvette
Former Vendor
How to repair the rolling up vinyl on a C4 Door Panel.
Old 10-09-2015, 10:08 PM
  #131
0Willcox Corvette
Former Vendor
ttt
Old 11-04-2015, 10:42 PM
  #132
0Willcox Corvette
Former Vendor
ttt
Old 11-08-2015, 10:52 AM
  #133
0Willcox Corvette
Former Vendor
bump
Old 11-16-2015, 12:59 PM
  #134
0Willcox Corvette
Former Vendor
This video won't really show you how to make a repair... but it will give you some insight on how the speedometer works and is assembled.
1978-1982 Speedometer assembly and discussion.
Old 01-11-2016, 10:07 PM
  #135
0Willcox Corvette
Former Vendor
Coming soon.. 53-62 steering column rebuild.. and
1963-1982 Corvette Steering column gear box rebuild...
Both are in the final stages of editing..
Old 02-17-2016, 12:10 AM
  #136
0Willcox Corvette
Former Vendor
ttt
Old 02-21-2016, 08:03 PM
  #137
0Willcox Corvette
Former Vendor
ttt
To Willcox Combined Video Thread!
Old 03-23-2016, 10:33 PM
  #138
0Willcox Corvette
Former Vendor
Newest Video.. 1970-1982 T-Top Weatherstrip Installation.
Old 03-24-2016, 12:43 AM
  #139
Majoho
Majoho's Avatar
How is the 63-82 steering gear rebuild video coming along?
Old 03-24-2016, 09:32 AM
  #140
Tom454
Tom454's Avatar
I had a big problem getting quality replacement gears and finally just gave up & put the old gear box back together. The gears are apparently all made "offshore" and the quality is terrible. I would like to know where to get good, American made gears. All the ones I got had big chunks missing out of the teeth.
Quick Reply: Willcox Combined Video Thread!
