1974 a/c compressor conversion
Old 08-09-2012, 06:39 PM
YANKEECORVETTE
YANKEECORVETTE's Avatar
Default 1974 a/c compressor conversion
I scored a set of JBA block huggers for my sm.block and want to run my a/c. I am thinking torward a Sanden compressor w/ Billet Specialties side mount brackets. Does anyone have a set-up done up like that or something simular? Pictures would be helpful. I want to stay awayfrom R4 compressors and reusing the old large compressor is not desirable for me.
Old 08-10-2012, 02:36 AM
oldalaskaman
oldalaskaman's Avatar
allen grove
http://www.google.com/url?sa=t&rct=j...fcO4pSsQpCrp0A
Old 08-10-2012, 07:21 AM
dmrodco
dmrodco's Avatar
Originally Posted by oldalaskaman
allen grove
wow sure glad you didnt go overboard on the details hope you didnt strain yourself
Old 08-10-2012, 08:24 AM
oldalaskaman
please confine your answer to the op's question with tech., this is tech. not off topic
http://forums.corvetteforum.com/foru...hijacking.html
forum rule, hope it helps
Old 08-10-2012, 04:14 PM
YANKEECORVETTE
Allen Grove looks good,I think 132r will fit the needs. I need to find Sanden 508 w/ the correct rear manifold for the factory lines. Thank you.
Old 08-10-2012, 04:17 PM
oldalaskaman
you can swap the rear heads on the sanden for bout $25 , real simple, hold on , I'll get you some info.
heres for the heads, I got mine from
http://www.ebay.com/itm/Sanden-A-C-A...ac34bc&vxp=mtr
this place has the correct rear head for the factory hoses listed
http://www.nostalgicairparts.com/ac/...s-heads-19.php
gm pad
http://www.nostalgicairparts.com/air...ad-back-16.php
I used the allen grove for both sanden a/c and alt. they work great
the video for the head swap
http://www.google.com/url?sa=t&rct=j...-rH95tvzB_nWOA
if your going to run 134, a VIR eliminator is a good thing
http://www.google.com/url?sa=t&rct=j...rdpwTrJjNF7bsA
I'm not advertising for the places listed , just where I got my parts
just went thru this b.s.hope it helps
btw the allen grove brackets will clear 'tall fabricated valve covers' for both the alt. and a/c. and the belts they suggest are the ones that work.
Old 08-10-2012, 06:56 PM
Seasoned80
Seasoned80's Avatar
Recommend the larger Sanden type compressor, 709, now known as SD4708. Model 4708 comes with the GM pad.
Old 08-10-2012, 06:58 PM
Seasoned80
Seasoned80's Avatar
OOPS-Sanden type SD7H15, Model 4708.
Old 08-10-2012, 07:12 PM
oldalaskaman
excellent , its a better unit also, seven cylinders versus five
Old 08-11-2012, 10:49 AM
YANKEECORVETTE
I ask for a cracker and you give me a steak. Thank you for the info it cut back on my homework!
Old 08-11-2012, 11:31 AM
kdf1986
kdf1986's Avatar
thanks for the posting on where to get the parts. I also book marked the Allen Grove site. I did not know this was available.
kdf
Old 08-11-2012, 11:55 AM
oldalaskaman
To 1974 a/c compressor conversion
Quick Reply: 1974 a/c compressor conversion
