How to clean an aluminum intake manifold, LT-1
Taking the top end apart to have the heads repaired. Whats the best way to clean up an original aluminum manifold?
I tried the search because I figured this has been covered a million times, but I didn't find anything........
Received 3,043 Likes
St. Jude Donor '05
soda blasting does a great job
having it tumbled will make it look like new.
beadblasting/sandblasting can dull/pit it if not done right.
I really don't like using any type of blasting media - it tends to change the surface characteristics and dull the numbers and the Winters snowflake.
I use Alumiprep 33 - this stuff is nasty; read and comply with the MSDS.
http://www.aircraftspruce.com/catalo.../alumiprep.php
If it's an original LT-1 intake, bead blasting can very well ruin the finish and if you're going for an NCRS resto you'll lose points.
Received 2,878 Likes
Hi Dan,
If you really want to be good to your intake you may want to consider sending it to Jerry MacNeish the Camaro guy who restores aluminum parts like intakes, valve covers, and surge tanks.
Regards,
Alan
Regards,
Alan
