LS3 swap water pump heater hose location probelm
I have a vintageair pulley system on an LS 3 swap that im doing and have to relocate the heater hoses. Has any one does this ? need a good location for the new hose holes. Already plunged the stock hose holes.
I tapped the holes an put in 90s to clear the control arm. I've seen people drill and tap directlt above the original openings at a 45 degree angle. You'll have to see how thick the material is around there to see if there's enough to tap.
Check out my post. I know it is long but some good info in it.
http://forums.corvetteforum.com/c3-t...o-my-72-a.html
