Bouncing speedometer needle
Old 09-05-2012, 09:41 AM
Ak. Mal
Ak. Mal's Avatar
Location: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Default Bouncing speedometer needle
I just changed the speedometer cable. It cut the amount of bounce considerably, but at 70mph there is still a +/- 5mph bounce. Do I need to lube up the speedo gauge? Is there a correct method and lube for that?
Old 09-05-2012, 11:01 AM
gcusmano74
gcusmano74's Avatar
Did you change the casing as well? If there is a short radius curve or kink in the casing, it might make the needle bounce. Also check the connection at the speedo head. It needs to be straight into the back and tight. Put white grease on the cable. Don't lube the gauge.
Good luck.
Old 09-05-2012, 11:47 AM
GOLF72
GOLF72's Avatar
Exactly... ^
Old 09-05-2012, 11:55 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
And don't put lube on the cable in the last 18-24" before the speedo head. Because the cable is wound-wire, lube tends to creep up the windings during operation. You do NOT want to get lube into the speedo head.
Old 09-05-2012, 12:39 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
You should clean the housing out if you aren't replacing it.
Where'd you get the cable from? Some come greased, some don't.
I ran mine in and out of the housing a few times to try to get all the crud out. Once it started feeling pretty smooth I ran a light layer of grease over it following Willcox's instructions. Works GREAT now!
Old 09-06-2012, 10:49 AM
Ak. Mal
Ak. Mal's Avatar
So I went and looked up the WilCox Corvette Speedo Lube Instructions. Where do you get the speedo lube they discuss?
I bought a brand new cable and housing.
Old 09-06-2012, 11:42 AM
Shark Racer
Man, I can't even remember off the top of my head. They have a few threads on this subject.
I ordered some ATP cables from RockAuto and they came with lube so I used that. However, the cables themselves were WAY too long so I ended up re-using the stock stuff.
To Bouncing speedometer needle
Quick Reply: Bouncing speedometer needle
