409hp @ 6k rpm and 427lb ft of torque @ 3500rpm?
I was thinking of tryin to build an engine using these specs,
this is out of Ryans engine combination and bible site.
(Combos 93 to 100)
Displacement: 350 cu. in.
Carburetor: Holley 750 double-pumper
Heads: GM L31 Vortecs, pocket-ported, with 1.94/1.50 in. valves
Intake: Edelbrock Performer RPM Vortec
Camshaft: Comp Cams Xtreme Energy 268 hydraulic, with
0.478/0.480 in. of lift and 224/230° of duration @ 0.050 in. of lift.
Exhaust: Hedman 1 5/8 in. headers
Distributor: HEI
Comp. Ratio: 9.4:1
MAX HP: 409 @ 6000
MAX Torque: 427 @ 3500
The vette I have is a 78 with a 3.08 rear and freshly rebuilt TH350 with original stall torque converter.
My question is, how would an engine act that reaches its peak torque way before max HP is reached. I chose it cause it looks cheap to build "non roller cam". What would be a good stall speed and rear end gear. Thanks
(Combos 93 to 100)
Distributor: HEI
Comp. Ratio: 9.4:1
MAX HP: 409 @ 6000
build it....then talk about problems like all of us do....
Why would you ever want to work out issues that don't exist?
BTW, you can't build an engine that reacts different than any engine out there...... HP/ TQ numbers will cross at the same point everytime.....
I'm also pretty sure this forum is here so that beginners like me can ask the more knowledgeable guys questions and get helpful answers
questions about what is wrong....(past tense) and questions what could go wrong.....future or (search)
then there is present....
Do you even have an engine to build? What stage is it in?
I never asked what could go wrong with the setup, just wanna know how it performs with those numbers. Right now the engine has a stock bottom end but the owner before my father said it has a edelbrock performer intake, carb and whatever cam kit he put in it, its definitely not stock. Its all edelbrock but when I rebuild it I'm gonna start fresh so I know whats in it. I have rebuilt engines before just never a 350.
yeah I've posted a lot of questions here and have always been given good answers, this is the first time I've been given a poor reply. As we say in the Army, "there's always gotta be one."
First delete that link to ryans pages It is infected with a trojan
@3500 peak torque is a good street engine compared to many stock engines come in @2800-3300rpm. Just install a higher stall speed converter to make up bottom end torque.
Personally I'll never build another 350 , when a 383 kit is so cheap or if your bottom end is solid, run an edelbrock top end kit until it blows then do the 383
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,925 Likes
You don't need much of a stall converter for an engine like this - a stock setup will work just fine. If you get the stall too high, the engine will simply feel sluggish and doggy from off-idle.
Lars
That looks more real-world.
Lars
Lars
The peak tq on my 427ci is @ 4750 RPM and peak HP is @ 6500 + RPM, I still have 360tq at the wheels at 2000RPM
I don't care where the hp and tq curves cross
Yeah, my blue car has a power band like that one and it's insane to think how hard the car pulls BEFORE it hits the meat of the powerband.
