1973 Heat & AC Wiring
Old 09-12-2012, 10:40 PM
Mariana
Mariana's Avatar
Default 1973 Heat & AC Wiring
Does anyone know where I can get the pigtails for the Heat/AC harness without buying the whole harness? When I got the car wires were cut and most pigtails were missing. I using the Dr. Rebuild Chart to ID what goes where, I just cans connect anything.
And how do I add photos to my posts?
thanks guys
Old 09-13-2012, 03:08 AM
oldalaskaman
oldalaskaman's Avatar
http://www.repairconnector.com/
Old 09-13-2012, 09:09 AM
oldsarge
oldsarge's Avatar
This link will help you to learn how to post pics.
http://forums.corvetteforum.com/c1-a...sual-aids.html
Old 09-13-2012, 10:55 AM
JohnRR
JohnRR's Avatar
Mariana,
It sounds like the previous owner of my '73 must have owned your '73 too. The wiring on mine was cut, spliced, and pretty much hacked up beyond all recognition I replaced all the wiring harnesses and kept all the old ones in a box in the attic. Of course, the parts you need are the ones my guy hacked to pieces. Consider purchasing just the A/C harness from Wilcox. Unfortunately, you'll have to remove the heater box to get it thru the firewall. Chances are the heater box probably needs some work too; mine did. And while the heater box is out.....
Hang in there,
John
To 1973 Heat & AC Wiring
Quick Reply: 1973 Heat & AC Wiring
