Rebuilt me steering control valve, some problems...
Old 09-21-2012, 09:53 PM
Sidepiper
Sidepiper's Avatar
Default Rebuilt me steering control valve, some problems...
I rebuilt my control valve and changed the hoses. While the car was off I turned the steering wheel full clock at least 50 times and large air bubbles were coming out of the power steering tank with the fluid level going up and down. When I started the car, the power steering only works when turning right but does not work when turning left. Any thoughts???
Old 09-21-2012, 09:59 PM
oldalaskaman
oldalaskaman's Avatar
adjust the valve
Old 09-21-2012, 10:06 PM
Sidepiper
Sidepiper's Avatar
While turning the steering wheel the fluid level fluctuates from halfway to over flowing,
Old 09-21-2012, 11:08 PM
wombvette
wombvette's Avatar
Adjust the valve.
Old 09-22-2012, 02:09 PM
Sidepiper
Sidepiper's Avatar
Do I turn the nut on the valve in half turn increments?
Old 09-22-2012, 02:24 PM
oldalaskaman
http://www.mamotorworks.com/corvette...-320-3861.html
Old 09-22-2012, 02:35 PM
Sidepiper
Sidepiper's Avatar
Originally Posted by oldalaskaman
Thank you but this does not relate to my current issue, The problem is not surging. The problem I have is when turning left I have NO power steering, I have followed Jim Sheas directions on bleeding the system for about an hour but I'm still getting huge bubbles. Is it possible I could be sucking air through the control valve? All lines have been checked for tightness and I see no noticeable leaks. Thanks again.
Old 09-22-2012, 03:08 PM
Peterbuilt
Peterbuilt's Avatar
Received 1,243 Likes on 965 Posts
Your pump and cylinder must be good since you have power one way but not the other.
Why did you rebuild the control valve? Was it just leaking or was this the original problem?
Do you have Jim Sheas papers?
Old 09-22-2012, 03:56 PM
Sidepiper
Sidepiper's Avatar
I did a complete suspension rebuilt and saw the control valve was leaking so I decided to rebuild it using willcoxs kit and YouTube video
Old 09-22-2012, 04:43 PM
Peterbuilt
Peterbuilt's Avatar
Willcox's video gets 5 stars, so look at it again and see if you can identify a part that was installed incorrectly, also PM Jim Shea, he can say for sure what part being installed backwards could cause the problem.
JS has a rebuild paper in here.
http://jimshea.corvettefaq.com/
Old 09-22-2012, 05:25 PM
Tiger62651
Tiger62651's Avatar
Yeah i had similar but i read the control valve needs to be adjusted. The lock nut under the dust cap needs to be turned. Turn car on allow the wheel to roll over. goto the control valve and adjust the nut slowly one way, should only take couple turns before wheels will move. depending which way wheels locked depends which way nut needs turning. adjust nut till wheels slowly turn the other way (not to fast trust me with hands in way it will jerk and take your arm) at this point adjust it back a 1/4 turn and you'll be centered. This was the simple guide i read, can't remember where but this was the simple basics.
Old 09-22-2012, 06:04 PM
Peterbuilt
Peterbuilt's Avatar
Default Calling Mr. Shea!
If it was a "centering adjustment" and you start the car the wheels will turn by themselves, then if you turn the steering wheel back the other way and let go it will turn by itself again.
Sidepiper bled the system but he only has power one way which makes me guess there is a problem in the control valve.
Lets see how this ends.
Old 09-22-2012, 06:59 PM
Sidepiper
Sidepiper's Avatar
Right on! I'm def. sucking air in somewhere, there's no way that this much air would be in the system. I'm beginning to think its the control valve, i'm positive I rebuilt it as shown on youtube but I'm wondering if the seal in between the two bodies is cut although I was super careful.
Old 09-22-2012, 07:45 PM
Peterbuilt
Peterbuilt's Avatar
Default This would be to easy...
Are you sure the lines are hooked up correctly?
Old 09-22-2012, 08:42 PM
Sidepiper
Sidepiper's Avatar
Yes all lines are hooked up right, triple checked. Also is it normal for fluid to push up in the power steering reservoir while turning the wheels when the car is off..?? Maybe I did get all of the air out of the system and this is normal. Just trying to eliminate things.
Old 09-22-2012, 09:04 PM
TPI BOY
TPI BOY's Avatar
Old 09-23-2012, 08:33 AM
oldalaskaman
when turning your wheels, the assist cylinder moves in and out causing the surging, if you havent already, you need to take the wheels off , take the cylinder loose , and center it per the instructions (including the one posted from mid america) after you do that , you may find that the other issue no longer exists.
hope this helps
btw, what fluid did you refill it with?
Old 09-23-2012, 12:18 PM
Sidepiper
Sidepiper's Avatar
Im done, Im going to take it off and send it off to get rebuilt as well as the assist cylinder. Never should have tried to rebuilt this myself. Adjusting the valve did nothing for my problem of no assist to the left. Thanks for everyone tried to help. Used gm power steering as suggested in Jim Shea btw.
To Rebuilt me steering control valve, some problems...
Quick Reply: Rebuilt me steering control valve, some problems...
