is it possible to swap zf6 into a c3
New member, have a 79 with 350 manual 4 speed, have a full flywheel/bellhousing back full drive train out of the 94 series LT1 zf6... is this a doable adaption? 1st time corvette project, lucked into the zf6 for a song, so could afford some additional costs to make it right. Looking for some street ability, and keep the 3.73 gear?
You might be better off selling the ZF to a C4 owner and putting a T56. The T56 needs a shifter relocation to fit the stock console but it's nothing a hacksaw and a welder can't fix.
I'm not sure if you need a hydraulic clutch with any of the newer transmissions but that is something that is relatively easy to do also.
Rick B.
Rick B.
