454 with interanlly balanced flexplate ?
i've got a "5445" casting motor mated to a th400 with an after market crank pulley and balancer. the motor is a replacement engine in a 69. the trans is original to the car.
i finally separated the two and found an internally (un-weighted) flexplate. i'm thinking that whoever replaced the original 427 motor just got lazy and used the old flexplate.
my question is this-the 5445 casting should be a 454 and need an externally balanced damper and flywheel (the th400 is going in one car and the engine into a 4 speed car), but how can i be sure which flywheel it needs without opening the engine? it's got good compression and ran well before i pulled it. i'm just trying to save a little work.
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19
that's a hard one, if your not sure of the life of the engine.
Is it possible that someone had some machine work performed on the engine and it could have been internally balanced?
If no one has had the engine internally balanced than it should have the weighted flex-plate.
I can't think of any way to tell without pulling the oil pan.
I've herd all 454 engines were externally balanced.
Neal
Neal
[QUOTE=L88Plus;1582151856]I'd think it would shake like a puppy dog passing a pine cone if it were that far out of balance.
Is the balancer external or internal balance?[/QUOTE
Check the balancer for a weight and check the part number of the flexplate and see what it is for.
I'm betting you have a replacement block with your original 427 internals inside. But your problem is an easy one if you don't want to look. Just reuse/replace your flexplate with a like/kind unit. No point in making this complicated.
It, however, is easy enough to check by just dropping the oil pan and getting the casting number off the crank if your curious.
ben, you were right. it's a 3904816 crankshaft stuck into a 454 block, and the counterweights are drilled.
my new question. with a shorter stroke, the original pistons would reduce the compression considerably. how can i determine what pistons are in the engine. i can't see any identifing marks on them.
427 and 454 blocks are identical. (some internal diffs in some years) If you take 427 internals out of a 427 block and put them in a 454 block you have the same engine.
