502 cam in a 427
Old 11-02-2012, 08:54 PM
Dr L-88
Dr L-88's Avatar
Received 1,240 Likes on 457 Posts
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default 502 cam in a 427
Has anyone used the ZZ 502 factory hyd roller cam in a stock 427 engine, and if so, what did you think about it....................power, drivability, sound, etc?
Here is a link that lists specs for the cam:
http://paceperformance.com/i-6255086...zz502-502.html
Old 11-03-2012, 01:19 AM
GDaina
Support Corvetteforum!
GDaina's Avatar
502 cam won't work in a mark IV Block...the cam snout on the 502 is different...
You can use a Mark IV cam in the 502 block but you have to mill the timing cover to give the cam button clearance.
Old 11-03-2012, 07:09 AM
L88Plus
L88Plus's Avatar
Sorry, GDaina, but you're wrong on this one.
ALL GM blocks have bosses (most drilled) to use the Gen 6 cam retainer plate. All you need to do is use the correct timing set since the holes are closer together on the Gen 6. Matter of fact, I know several builders who have stopped using Mark IV type hydraulic roller cams and gone straight to Gen 6 - no cam button, etc., in all their Mark IV builds.
Old 11-03-2012, 09:00 AM
GDaina
GDaina's Avatar
I am talking about the BBC 396 - 454 cams produced from 1965 - ? Designated as Mark IV engines
I do have a spare 427 block will take a look for the holes.....if I'm wrong then I'm wrong....
Old 11-03-2012, 09:08 AM
GDaina
GDaina's Avatar
Cloyes does make a double roller, but it is quite expensive...I was considering that but decided to stick with the single chain.
I did make the Mark IV roller work in the 502 block....till one of the roller imploded...since I liked that cam so much I just had it ground for the retaining plate
Old 11-03-2012, 09:22 AM
Dr L-88
Dr L-88's Avatar
The cams WILL interchange if you use the correct timing set.
All I wanted to know was.............................
Old 11-03-2012, 09:35 AM
GDaina
GDaina's Avatar
Bad link
To 502 cam in a 427
Quick Reply: 502 cam in a 427
