Corvette Rear Fiberglass Composite Leaf Spring
Old 11-12-2012, 04:50 PM
79c3man
79c3man's Avatar
Default Corvette Rear Fiberglass Composite Leaf Spring
want to put one on 79 corvette ,which brand trw or Hyperco and which weight
Old 11-12-2012, 04:52 PM
Denpo
Support Corvetteforum!
Denpo's Avatar
AFAIK only VBP's will give you correct ride height without 8" bolts.
Old 11-12-2012, 05:31 PM
shrekviper
shrekviper's Avatar
The ride is solid without being jarring.
Old 11-12-2012, 06:11 PM
drwet
drwet's Avatar
TRW 330 lb. Love it!
Old 11-12-2012, 08:57 PM
gcusmano74
gcusmano74's Avatar
Depends on what you are trying to do.
If you just want to replace a rusted out rear spring, and don't want to change the handling balance of the car, use the Hyperco EZ Ride. The rate (200 lbs/in) is very close to the factory spring. And you will be able to use a stock type shock.
The VB&P springs start at 300 lbs/in and go up from there. It will change the steer characteristics of the car, and require a stiffer shock to control it. A lot of fellows like the Bilstein Sports for that sort of application.
I am running stock front springs (280 Lb/in), and a 15/16 front stabilizer bar on my '74 smallblock convertible. In the rear, an EZ ride and a 9/16 bar. Very sweet ride, nice handling. (I am no longer 22. Heck, it's been a while since I was 52!)
Old 11-13-2012, 02:12 AM
SuperBuickGuy
SuperBuickGuy's Avatar
what are you look for in a spring? race? cruise? better ride?
Old 11-13-2012, 04:16 PM
Kid Vette
Kid Vette's Avatar
Actually VBP's come with 8" bolts and you will need them to get stock ride height. Stay away from the TRW springs; many (myself included)have had ride height issues, even with 8" bolts. Haven't heard much about the Hyperco's - I guess no news is usually good news.
Old 11-13-2012, 04:24 PM
Denpo
Denpo's Avatar
Thanks for correcting me kidvette.
I think Hyperco are just like TRW springs, you know, the ones that get wider at the extremities.
Old 11-14-2012, 12:36 PM
bdchase73
bdchase73's Avatar
Having ride height issues with mine as well. Has 8" bolts. Any suggestions on how to get this to sit down in the back? Can you get 10" bolts? I know she is to ride about 26" to the top of the fender ridge. I am more like 32"
P.S. Sorry about the post here, not trying to steal the thread, just frustrated and need help!
If anyone thinks they have info please look at this post. THANKS!
http://forums.corvetteforum.com/c3-t...de-height.html
Old 11-14-2012, 03:55 PM
Kid Vette
Kid Vette's Avatar
Looks like you got a TRW spring with that kit. They are manufactured by Muskegon Brake and have known ride height issues. I tried 2 before I gave up and bought a VBP spring. I suggest you do the same. If you are running 15" wheels you shouldn't use any longer than 8" bolts. You can get away with 9" bolts with 17" wheels. Any longer than that and you risk having the spring end puncturing the side wall of your tire. There is a reason suppliers don't list the 10" bolts for a C3.
By the way, you will get a 1:1 drop by loosening the nut on the spring bolt.
One more thing, the ride height in the rear should be set by the halfshaft geometry. You want the halfshafts about 1/2" higher near the differential than near the wheel.
Old 11-14-2012, 06:26 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
Years ago, when my wife still had her '79, I installed a VB&P 330 in/lb rear spring in it. I had no issues with ride height, used stock length bolts, and LOVED the ride quality.
(I used Monroe-Matic gas shocks, IIRC)
To Corvette Rear Fiberglass Composite Leaf Spring
Quick Reply: Corvette Rear Fiberglass Composite Leaf Spring
