factory side pipes
Old 12-05-2012, 02:50 PM
70demi
70demi's Avatar
Default factory side pipes
Trying to mount factory 69 side pipes on my 70 vette / Need the best method to do it . I have the exhaust sidepipes mounted already , just need to figure how to mount the shields. Do you leave the 70 rockers on and bolt the insulators and shields setup to the rockers? If so would like to find a pair of used 70 rockers that I can customize. Thanks
Old 12-05-2012, 03:59 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by 70demi
...Trying to mount factory 69 side pipes on my 70 vette / Need the best method to do it...
Purchase the 69 assembly instruction manual and follow the factory installation diagrams. Stock rocker panels are not used. 68 and 69 use two piece rockers; 70 and up are one piece.
Old 12-05-2012, 04:26 PM
Hammerhead Fred
Hammerhead Fred's Avatar
You gotta remove the rockers. You'll then find the cover holes don't align with the rocker mount points. To attach the cover to the rocker area you'll need to insert some type of threaded nut behind the frame rail/body lip to receive the screw. I was unable to figure out how to mount the ones provided with the covers. You can get them in there but didn't see a way to hold them in place while installing the cover. I tried several other blind nuts and finally went with nylon (similar to the self expanding household anchors because they were much easier to insert into the tiny area where the nuts belong. Suspect the nuts on the 69 are installed before the body is mounted to the frame.
Old 12-05-2012, 06:27 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi 70,
The side-pipe shield needs to be installed before the side pipe.
The large forward bracket on the shield can't slip into position with the pipe in place.
I needed to drill new holes too.
I test fit both the pipe and shield before drilling any holes. If the shield is mounted too high on the rocker channel the bottom of the pipe is visible.... not a good look.
Regards,
Alan
Old 12-05-2012, 07:19 PM
Hammerhead Fred
Originally Posted by Alan 71
Hi 70,
Regards,
Alan
what he said...
While I was able to get the shield on after installing the side pipes it indeed took very careful manipulation of the shield to get the front started and then swing the rest into position. Pipes last would definitely be easier. And my shields are mounted as high as I could get them to cover the rocker area which does leave the lowest portion of the pipe exposed.
Old 12-05-2012, 07:54 PM
gbvette62
gbvette62's Avatar
Received 2,029 Likes on 1,315 Posts
Originally Posted by Hammerhead Fred
what he said...
It's been years since I installed a set of factory side pipes, but I do remember that it was a lot easier to put the covers on, before the pipes.
If you have a 70 assembly manual, you may want to look at the accessory section, in the back. It seems to me that the 70 AIM had a section on installing the factory side pipes, with the page marked "cancelled". I think that Chevrolet contemplated offering the side pipes on the 70 Corvette, but cancelled the option, just before production started.
Old 12-05-2012, 10:26 PM
70demi
70demi's Avatar
Default shield install
OK, Thanks for the information guys, I'm going to give it another whirl tomorrow.
Old 12-06-2012, 07:43 AM
Alan 71
Alan 71's Avatar
Hi,
Here's what I felt was a reasonable compromise between having the pipe covered and the shield at an acceptable height.
These are 69 shields painted black.
Regards,
Alan
Old 12-06-2012, 10:15 AM
70demi
70demi's Avatar
Default Question?
Height looks nice, did you have to alter the front shields or did you need to alter the cars body ?My front shields are going to be hiting the front of my body ? (ROCKER PANEL AREA)
Old 12-06-2012, 11:09 AM
fazang
fazang's Avatar
Does this installation guide help ???
http://willcoxcorvette.com/instructi..._1969-1982.pdf
-ALF out....
Old 12-06-2012, 03:21 PM
Alan 71
Alan 71's Avatar
Hi 70d,
Yes, the forward end of the fiberglass rocker panel needs to be cut for both the pipe and for the shield.
Regards,
Alan
Old 12-06-2012, 06:29 PM
70demi
70demi's Avatar
Default install
Got the shields "mocked" in today after trimming out what needed to be, ordered new retainers an screws.now we wait patiently. But my wife says ,I'm not to good at that.
Old 12-06-2012, 09:19 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a step by step with the AIM page info too...
http://willcoxcorvette.com/repairand...lp.php?hID=199
Old 12-06-2012, 09:54 PM
70demi
70demi's Avatar
Default install
Holy Mackeral, I'm kinda of a computer illerate, but I followered your illustrations that you sent earlier,along with everyone elses suggestions. Waiting for my new screws an retainers to arrive. Thank you and to everyone else. I really appreciate it
Old 12-21-2012, 04:20 PM
70demi
70demi's Avatar
Default Mounted
Got the setup on an they look good and sound even better. Thanks guys for all the help an encouragement. And Merry Christmas
Old 12-21-2012, 05:01 PM
CF6873
CF6873's Avatar
Where are the pics???
Old 12-22-2012, 12:19 PM
70demi
70demi's Avatar
Default pics
Like I said in a former response , I'm kind of a computer nitwit ,but I'll try.
To factory side pipes
Quick Reply: factory side pipes
