rear main cap bolt toque
what is the torque on the rear main cap bolts. The other main caps are 4 bolts but the rear main cap is 2 bolts. anyone know what to torque the 2 rear main cap bolts to? I believe its 60ftlbs but i might be wrong. 1980 corvette
Bolt torque?
All the "long" main bolts (10) get 70# (with oil) and the "short" outers (6) get 65#.
Thanks, Gary in N.Y.
P.S. This is G.M.'s recommended numbers using their fasteners!
ok so what is the torque for the rear main bolts on the rear main cap? the rear main cap only has 2 bolts not 4 like the other caps.
The long bolts on either the 2 or 4 bolt caps are 70ft/lbs. The rear cap, with 2 bolts is still 70ft/lbs. Short bolts on the 4 bolt caps, IIRC, is 65ft/lbs.
