Correct distibutor module grease?
I've got my distributor out. I'm cleaning out the inside of the casting. I removed the module and want to put a fresh coat of grease under it. I've got dielectric grease that I use on the spark plugs and wires. Is this the correct grease to apply to the underside of the module? I seem to remember the grease to use was white. The dielectric grease is clear. Thanks all.
This would work. Most computer supply/repair shops carry it.
http://www.radioshack.com/product/in...ductId=2102858
this is the one I use from Radio Shack, for 1 tube it was about $7.
recommended by another member in another thread, works well.
http://www.radioshack.com/product/in...uctId=15545986
If you didnt buy anything from Radio Shack, here is what you need for a bit less that you would probably spend at the shack.
http://www.autozone.com/autozone/acc...mString=search
Use a lot...cover the bottom completely...also, only use a genuine part from the dealership if you ever have to replace it. I have a MSD distributor and it went out twice on me. Got an original part from the dealership...no problems...that was fun...
