Electrical problem, high beam flicker
Old 01-10-2013, 09:46 AM
Surfer69
Surfer69's Avatar
Default Electrical problem, high beam flicker
I replaced both high beams because they were flickering after a couple minutes of being on. Thought the bulbs were bad but now it's still doing it.
Anyone have any ideas? Happens in both bulbs almost like a short or something. Regular low beams steady with no flickering.
Old 01-10-2013, 09:50 AM
jnb5101
jnb5101's Avatar
high beam switch?
Old 01-10-2013, 10:00 AM
'75
'75's Avatar
Do the outer lamps do it too or just the inners?
Old 01-10-2013, 10:50 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Loose ground wire to headlamps;
Loose power wire to headlamps;
Fraying power or ground wire that is [intermittantly] making bad connection;
Defective dimmer switch;
Defective voltage regulator in the alternator.
If you see the voltmeter 'jump' at the same time as the headlights 'flicker', you could have a loose or bad wire/connector on the battery.
Old 01-10-2013, 11:50 AM
Surfer69
Surfer69's Avatar
Yeah I think I should do some testing and try and eliminate some of the suggested possible causes. High beam switch sounds like a prime candidate. Ground also but seems low beams would use same ground and they dont have a problem.
Old 01-10-2013, 12:35 PM
7T1vette
7T1vette's Avatar
If flicker is only on hi-beams lamps, the problem is most likely wiring related (between dimmer switch and where it separates for the 2 high beam feeds), or in the hi-beam portion of the dimmer switch. Carbon deposits/corrosion on the switch contacts is a very good possibility.
I would choose to disassemble that dimmer switch and clean/repair the original switch...unless it is found to be "toast" internally.
Old 01-10-2013, 03:07 PM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
There is a circuit breaker in the headlight switch, over the years it becomes sensitive to too many watts.
Old 01-10-2013, 05:50 PM
7T1vette
7T1vette's Avatar
If that circuit breaker is only for the hi-beam lights, it could be the problem, too. If it feeds all the lights, it is still possible, but unlikely to be the cause.
Old 01-10-2013, 06:25 PM
Mashman
Mashman's Avatar
I agree.
I had this issue also, and it was the headlight switch. Turn on the high beams, and after a couple of minutes, something would heat up, and the lights would go off. A second later (I guess after something cooled off) and the lights would come back on.
Old 01-11-2013, 09:29 AM
Surfer69
Surfer69's Avatar
Originally Posted by Mashman
I agree.
Yeah that's it but the problem is I just put a new light switch in less than a year ago. Maybe it's a POS China crap or something?
Old 01-11-2013, 11:14 AM
7T1vette
7T1vette's Avatar
Headlight switch just sends power to the lighting system; it doesn't 'know' which set of lights are being illuminated. Not the switch.
Old 01-11-2013, 12:01 PM
blackbeauty74
blackbeauty74's Avatar
Im to having the same problem with my high beams. Im changed the dimmer switch but no change. The wiring to the lights looks a mess. Im thinking about replacing the whole front wiring harness but im unsure of the difficulty .
Old 01-11-2013, 01:32 PM
'75
'75's Avatar
The circuit breaker in the headlight switch is for all the headlights. When the hi beams are on, 4 lights are illuminated, therefore more current is used so if the circuit breaker is weak, it would trip while using the high beams. That said, when it trips, all 4 beams would go out for a second or two, then come back on. A quick flicker where the lights do not go off completely before coming back on is not likely a problem with the circuit breaker in the switch. So which lights are flickering, all 4 or just the two middle ones.
Old 01-11-2013, 02:34 PM
redman76
redman76's Avatar
St. Jude Donor '09
Exact same here. I did not have that issue until I replace mine with new switch. I'm wondering same thing . . . poor quality or bad batch? I bought mine from one of the supporting vendors and plan to pull it this winter and send back for them to test.
Old 11-04-2013, 10:09 AM
Surfer69
Surfer69's Avatar
Update: Turned out to be broken wires that attach to the plug/sensor at the mechanism unit. This means those also connect the complete circuit at least for the high beams. I thought they were just the dash light switch only for when the doors are not fully open. FYI
Old 07-31-2017, 10:45 AM
Storm059
Cruising
Support Corvetteforum!
Storm059's Avatar
Which mechanism are you talking about? i am having the same trouble with headlights going out only on high beam. they come back on but in a few seconds out again. switch to low and they stay on.
Old 10-19-2020, 05:33 PM
68vet427
68vet427's Avatar
Hi,
what plug / sensor mechanism you talking about?
Do you remember?
I am having the same problem.
Thanks,
Joe
To Electrical problem, high beam flicker
Quick Reply: Electrical problem, high beam flicker
