Tri-power vs 4 barrel
I'm putting together a dart 565 with AFR 300 oval port heads. I want to keep the stock BB hood, so I'm looking at the torker II or the oval port tri-power intake. With the 3 carbs I will get about 1300 cfm and decent mileage with the center carb. I'm looking at about 6500 rpm. Would the tri-power intake feed the air requirements of this engine better then the torker II?
The tri-power looks great under the hood. I've never heard anyone brag about mileage from a Holley four barrel on a big block but they do make power especially towards the upper RPM ranges. Any tri-power intake has air flow compromises if it fits under a stock hood. A good four barrel intake would run better overall. It really depends on what you want. A properly set up Quadrajet (the Lars way) would probably be the ticket for good performance and give the bonus of reasonable mileage for your application.I would assume that a huge motor with oval port heads is being built for more mid-range than top end anyway.
A friend of mine has a Dart 494 big block in a 65 Pro-Street car. He liked the look of the 67 stinger hood, and didn't want to run a big scoop, or a hole in his hood. He tried all different kinds of 4bbl intakes, and nothing fit under his hood.
He ended up with a 68 factory tri-power intake, and a modified set of original Holleys, with progressive linkage.
He doesn't race the car, or anything like that. It's mainly used for "serious" cruising. With 4:56 gears and a manually shifted racing Powerglide, his gas mileage sucks, with or without a 2bbl!
I can't believe this question. If you have a tri-power, run it. It might be hard to find an oval port tripower manifold. I have a rectangular port tripower L71 and went through this exercise recently when I wanted to go to alum heads. I was told running a rectangular port manifold on oval port heads would not affect anything.
Bling forever.
Ralph.
Bling forever.
Ralph.
Bling forever.
Ralph.
Bling forever.
Ralph.
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Do a search here on 632C2. Steve Barker did an incredible big inch motor with a tripower and even used iron exhaust manifolds. LOTS of porting..but it made 680 RWHP and he gave ALL the details of his carb setup to feed it. Don't even begin to think about using stock carbs etc. Those AFR 300's may be oval shaped but they aren't tiny ports.
JIM
JIM
Received 3,043 Likes
St. Jude Donor '05
They are both going to strangle that motor come on 565 is no puny mill
Maybe with serious porting it will help
Put what bling you want I guess....mileage? 565 ? Serious?
Not an expert on what intakes would fit but if it were me Id look for a Team G low rise, port that use a drop base air cleaner and stick it on. Will outflow either of those two no problem and be simple to maintain 1 carb
One alternative of factory kit you may want to consider is to match an LS6 intake down to those large ovals, using epoxy. Tri-power intakes are worth too much to mod, IMHO, and it's worth pointing out that C2 ones are taller than those designed for C3s. And, I wouldn't advise that anyone try to re-invent the 3x2 secondary linkage.
St. Jude Donor '05
gve all the testing Ive seen on that ranks it about neck and neck with the edelbrock RPM within a few ft lbs then walks away up top.
Its an old design but it works well. Ported mine top to bottom noticeable difference and isnt a pig down low. Probably running a lot more cam than most too. Is it the best....maybe not but Im guessing it would fit.
Probaby still wont keep up with the AFRs but should do real well. So much torque why bother with a dp anyway
My opinion is that the 3x2 barrel intake are a better design and producing more power then the LS6 intake.
My brothers 68 convertible with a ovalported 3x2 carb setup pulls easy to 6000rpm and produces great power.
His 427 has not been in the dyno but it definetly produces more power then my LS6 replica (470hp/5500rpm) and also easy pull 500 or so more rpm;s.
The conditions for those engines are different but my point is that with the correct camshaft, ovalport heads and a 3x2 carb setup there are good chances for a strong durable engine.
Take a look at VetteWeb;s project car feturing a 454 with large port AFR heads and a 3x2setup with a 3x2 fuel injection throttle body setup.
http://www.vetteweb.com/tech/vemp_11...tte_dyno_test/
The "Big-Block Party" 1969 convertible produces 600hp, still everything stays hidden by the original bigblock hood.
I would definetly go for the 3x2 setup.
If one looking for hp, it flows a lot of cfm.
If one looking for attitude, it looks nice.
//Ricky.
//Ricky.
The center carb is rated at 350 CFM, the end carbs are rated at 466CFM for a total of 1282. However... 2 barrel carb lab rating procedures are different than 4 barrel lab rating procedures. When you rate the 2 barrels using the 4 barrel procedure, the numbers are 250 center & 333 end for a total of 916 CFM. So if you are trying to compare the GM TriPower to a 4 barrel carb, you have to use the 916 CFM figure to compare apples & apples.
2022 C2 of the Year Finalist - Modified
Hi Tom,
Any idea what a BG Sixshooter 3x2 set up flows in 4 bbl terms?
BILL
