hei question
No start? A testlight from the TACH terminal (Tach disconnected) to ground and crank the engine. If the light flashes, the module and pickup coil are good.
GM had a module tester that heated the module and did a diagnostic thing- but it was a go-no go thing IIRC. Maybe parts stores have got them too.
here is what happend I was drivng and all the sudden car quite just like it shut it off pulled over checked some wiring all was good waited about 20min or tried to start and it started drove home no issues ckecked further for wireing issue did too ground found nothing so far car starts
I had a pick up coil break on an HEI, when the dizzy advanced the car would quit and when the car quit and the dizzy retarded the car would start
