BBC Elec Fuel Pump or Keep Mechanical
Old 01-31-2013, 05:14 PM
roger3
roger3's Avatar
Default BBC Elec Fuel Pump or Keep Mechanical
Trying to decide if I want to keep the Edelbrock 110 GPH mechanical fuel pump or switch to electric pump.
I have a bbc in my 76 vette that makes about 540 hp.
I just took motor out to switch from solid roller to hydraulic roller. Fuel pump rod (comp Cam Rod with soft bronze or brass tip) soft end was mushroomed. Motor has about 5000 miles and 70 1/4 mile passes. I was surprised to see it mushroomed. Is that common?
If I would have kept driving it might have had a problem to figure out and fix.
I have read so many different opinions about electric pumps (good and bad, noisy, break often, short life, never had a problem).
This electric pump looks good. Any comments?
http://www.summitracing.com/parts/edl-1791
Roger
Old 01-31-2013, 05:37 PM
roscobbc
roscobbc's Avatar
I run stock fuel pump with 528hp 489cu in and 950cfm dp - never have a fueling issue!
Old 01-31-2013, 07:40 PM
gator79
gator79's Avatar
keep the mechanical pump
Old 01-31-2013, 08:35 PM
auavette
auavette's Avatar
I do run a blown 496 with dual 780 cfm prosystem carbs and I am using a mechanical pump
Old 01-31-2013, 08:48 PM
roger3
roger3's Avatar
Thanks for the feedback. Keeping what I have is easy.
Any thoughts on the mushroomed fuel rod?
Roger
Old 01-31-2013, 09:36 PM
roger3
roger3's Avatar
What mechanical fuel pump and fuel pump rod are y'all running?
Old 02-01-2013, 12:00 AM
DRIVESHAFT
DRIVESHAFT's Avatar
What material is the new hydraulic roller made of?
You may be able to switch back to a normal steel push rod.
Old 02-01-2013, 01:08 AM
SuperBuickGuy
SuperBuickGuy's Avatar
that mushroomed tip is the issue - good thing you caught it before the motor ran lean.
I like mechanical whenever possible... with that said (and especially because it wouldn't be that hard to do) if I had to, I would run a submerged pump and a bypass regulator. More likely, I'd use one from a stock, GM vehicle and submerge it in your tank - they last longer because they run cooler.
Old 02-01-2013, 01:25 AM
babbah
Support Corvetteforum!
babbah's Avatar
Old 02-01-2013, 01:28 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Those tips are designed to wear
Bronze dust doesnt hurt anything
I use a lightweight Howards composite love it!!
Keep the mech 1 less thing to go wrong.
Old 02-01-2013, 07:58 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
It may be seen as swimming upstream, or as an exception to "the rule", but I've NEVER had a problem with an electric fuel pump on a high-perf application (street, strip or road course), which is something I just can't say about mechanicals. Holley 110 GPH Blue here. My $.02
Old 02-01-2013, 09:22 PM
zuendler
zuendler's Avatar
Sadly my new 502 had not the possibility to mount a mechanical pump. I want to keep the engine as simple as possible. Had my mech pump some years at the 454 without problems.
And now i have this noisy thing near the tank - i dont like it. And additional i needed a fuel preassure regulator, another thing that made me work to install and that could break one day.
Old 02-01-2013, 09:44 PM
roger3
roger3's Avatar
I believe it's a steel roller. I called Chris Straub (I bought it from him) and asked what fuel pump rod to use. He said I could use an OEM rod. I didn't ask what material the cam was made of.
Roger
Old 02-05-2013, 05:27 PM
Cstraub69
Cstraub69's Avatar
99% of my hyd rollers are made from SADI cores. These are 100% USA made. They are stronger than the GM 1050 steel and are rated for 260# seat and 650# open with a 20% safety factory.
Old 02-05-2013, 05:34 PM
SuperBuickGuy
Originally Posted by Cstraub69
...... with a 20% safety factory.
I know what you meant, but sometimes inadvertent makes for great humor.
Now I know why I keep breaking stuff, I forget to buy from the safety factory
Old 02-06-2013, 12:00 PM
Street Rat
Street Rat's Avatar
I vote to keep things simple and run a mechanical type pump. Unfortunately the short block that I'm building has no provision for a mechanical pump. I've been searching the archives for ideas on mounting and plumbing an electric pump.
Old 02-09-2013, 09:00 AM
roger3
roger3's Avatar
Dynoed my engine this week. Mechanical fuel pump couldn't keep up with fuel demand.
First few pulls using shops electric fuel pump. A/f fuel ratios look pretty good throughout.
Switched to my Edelbrock 110 gph mechanical pump. Making pulls from 3500 rpm to 6000 rpm, (6 second pull), A/F ratios start leaning out near the end. So for an 11.5 second 1/4 mile run, I would lean out even more.
I do like the idea of keeping things simple so if I can find a mechanical pump for High flow that's what I'm leaning towards.
Any of you using a high flow mechanical pump that you recommend?
Roger
To BBC Elec Fuel Pump or Keep Mechanical
Old 02-09-2013, 11:32 AM
Cstraub69
Cstraub69's Avatar
Roger
Clay Smith
Old 02-09-2013, 12:04 PM
DRIVESHAFT
DRIVESHAFT's Avatar
What kind of HP did you make? Are you still around 540? That's obviously going to make a difference.
I'm pretty surprised that your Edelbrock couldn't keep up.
There are quite a few higher output mechanicals though.
I use the Holley 130 gph mechanical with a regulator.
Holley also sells a 170 gph that doesnt need a regulator.
Both of those pumps actually flow about the same at running pressures.
On paper they both flow way more than you should need.
They also make some billet pumps out there that will flow more, but they get really pricey.
Holley 200 gph http://www.summitracing.com/parts/hly-12-454-30
I have not dyno'd my car so I can't say that I'm positive that I'm not sucking the float bowls dry.
I do have a wideband O2 sensor & a gauge in the car, and what I've seen there has never worried me, but its pretty hard to watch the gauge when my foot is hard on the throttle.
Old 02-09-2013, 12:44 PM
DRIVESHAFT
DRIVESHAFT's Avatar
Here are a couple of billet pumps that I forgot about that are a bit cheaper than the Holley Ultra HP billet pump..
Holley HP billet 170 gph pump http://www.summitracing.com/parts/hl...7-25/overview/ [it flows more than Holley's "normal" 170 gph pump]
Carter Billet 180 gph pump http://www.summitracing.com/parts/cr...make/chevrolet
Quick Reply: BBC Elec Fuel Pump or Keep Mechanical
