Dipstick question
Dipstick question
The dipstick tube on my 76 comes out when I pull out the dipstick. Is it supposed to be press fit into the block? Is there supposed to be an o ring to keep it from leaking? Any tips on fixing it?
No the holder should stay in place. It is a pressed fit but not that much of super pressed fit. When I changed mine to a chrome replacement I was able to just grab the holder and pull it right out. However the chrome one was a sloppy fit. To fix it I took a cotton swab with alchehol and cleaned the hole in block and used high temp sealant on the holder and put back in block. I let it set overnight and no problems, doesn't pull out or leak.
