Mildon BBC Stud set Torque?
Old 02-06-2013, 05:50 PM
gve
gve's Avatar
Default Mildon BBC Stud set Torque?
I just bought a Mildon windage tray #32260 and stud kit for mounting the windage tray #8115. On the stud package it says to torque the nut to 85 ft/lbs the 4 bolt main specs for a BB I think are 110 ft/lbs what should I do? Are studs torqued different then bolts? I would hate to torque the stud nut to 110# and stretch the stud or threads and have a failure.
Old 02-06-2013, 05:59 PM
7t9l82
7t9l82's Avatar
use what the manufacturer suggests. they make a quality product, also use the lube the suggest
Old 02-06-2013, 11:24 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Haven't used Milodon main studs in a while, but ARP's procedure is to install the studs finger tight, with a small amount of thread locker for permanent mounting, then to torque the nuts (incrementally in three steps) before the locker sets, to 110#. That said, I'd double check with Milodon before going beyond their specified value. Magic potion on the nuts is a good call.
Old 02-07-2013, 01:07 AM
TimAT
TimAT's Avatar
Do the Milodon studs have a stop on them for the main caps and then an extension over that for the windage tray?
This is a FACTORY SBC windage tray main bolt. The BB ones I have a very similar.
Old 02-07-2013, 01:38 AM
Manuel Azevedo
Manuel Azevedo's Avatar
Do what the manufacture says!! If these are real studs and not a bolt the studs have fine threads with nuts at the cap, these have more mechanical advantage than the stock bolts with coarse threads. You also only torque the studs about 10 lbs into the block if I remember correctly.
To Mildon BBC Stud set Torque?
Quick Reply: Mildon BBC Stud set Torque?
