82 monoleaf spring replace???
Old 02-14-2013, 02:25 PM
Jerry82
Jerry82's Avatar
Default 82 monoleaf spring replace???
greetings again!
i am looking to restore the rear suspension(just did the front) i see that the kits do not include the spring. the car has 75k miles good stance and height. should the monoleaf be replaced or am i ok just with the bushings, shocks, etc..
thanks everyone.
Jerry
Old 02-14-2013, 04:27 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
The '82 came with a monoleaf spring. If it isn't damaged and doesn't look like there are any signs of delamination, just use what you have.
If you are in need of stiffening the suspension for road racing, etc., you might want to change from the 'soft' stock spring to one with a 300-330# rate. The stock unit only has about a 180# rate; it gives a smooth ride, rather than a firm one.
Old 02-14-2013, 04:43 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by Jerry82
...75k miles good stance and height. should the monoleaf be replaced...
They're not supposed to wear out.
Old 02-14-2013, 04:50 PM
Jerry82
Jerry82's Avatar
Default cool, thank you gents!
it just a nice cruiser no racing.
Old 02-14-2013, 05:39 PM
Wrecked82
Wrecked82's Avatar
I have 225K miles on the original monoleaf spring with no sign of needing to be replaced. I say leave well enough alone.
Old 02-15-2013, 10:54 AM
Jerry82
Jerry82's Avatar
WOW!!! then i surely have no problems!!!
Old 02-15-2013, 04:00 PM
hugie82
hugie82's Avatar
I'm well over 100k and no problems at all! I would only change it if I needed better handling for the track but you can't beat the smooth ride
To 82 monoleaf spring replace???
Quick Reply: 82 monoleaf spring replace???
