Radiator
Old 03-28-2013, 10:17 AM
billkat
billkat's Avatar
Default Radiator
Is there a secret to get the shroud out of the car ? maybe remove the shroud with the radiator ? I dont want to screw up putting it back together with a new aluminium radiator.
Old 03-28-2013, 10:33 AM
vettestu
vettestu's Avatar
undo the six bolts holding the radiator and frame to the front clip. this will allow you to move the assembly forward enough to get the shroud out. I used a tie down ratchet to gently pull it forward
Old 03-28-2013, 10:42 AM
hwcoop
hwcoop's Avatar
I am about to go through this same exercise. Last time i did it I found the following seemed to work.
-Remove Hood
-Remove Fan assembly
-remove the 6 side bolts holding the Rad support, 2 support to crossmember and the brace
I pulled the whole unit out as an assembly and reinstalled it.
I'll take some pictures when i do it next week and document the process.
Bought Aluminum Direct fit from Zip for $399. (says made by Dewitts)
hope this cools the 454
Old 03-28-2013, 10:48 AM
billkat
billkat's Avatar
Radiator is out. The the radiator support is shot so I will have to replace that. Can I use stock brackets on an aluminum direct fit radiator ?
Old 03-28-2013, 11:27 AM
billkat
billkat's Avatar
-Remove Hood
I found a Dewitt Direct fit at $499.00 and abother Dewitt labled as a replacement which is $399.00, I dont know what the difference is.
Old 03-28-2013, 11:32 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Contact DeWitt's and ask. For Direct Fit, your stock brackets and cushions should work.
To Radiator
Quick Reply: Radiator
