Drag Radials for a 1978
Old 03-28-2013, 01:50 PM
jtalka
jtalka's Avatar
Default Drag Radials for a 1978
Guys;
Any recommendations (brand and size) on a set of drag radials for my 1978? The body is bone stock and I am not looking to modify the rear wheel openings...
Thanks!
Joel
Old 03-28-2013, 01:59 PM
DRIVESHAFT
DRIVESHAFT's Avatar
Mickey Thompson 255/60R15
Old 03-28-2013, 06:08 PM
BKbroiler
BKbroiler's Avatar
I've just about finished off my second set of BFG drag radials 275/60/15 on stock 8in aluminum wheels. I had to move the ebrake cable bracket for clearance. Consistent 1.70 60ft times when running 12.40 -12.50 ETs, so it's leaving pretting hard.
Old 03-28-2013, 09:17 PM
lance m p
lance m p's Avatar
Default Yep that Vettes leaving...........>
pretty hard, same tire I run on my T/Regal can't really compare cars>like apples & oranges T/Regal runs 10.50-60's @ 128 or so.....60ft 1.30-40 alcohol injected/TE-61/42-1/2lb injectors.....etc.so I'm cheatin!......street legal........> Nice Vette!
Old 03-28-2013, 09:33 PM
lance m p
lance m p's Avatar
Default I'll say this on the BFG Drags............>
I had to screw the rims to the tires....they were hooking that hard. Had M/T slicks on it and not a whole lot of diff. in the 60ft. maybe a 10th.
Old 03-28-2013, 10:04 PM
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
These little 255/60 MT ET Street radials will do work...
I go 1.51 60's on them...
275/60s also work great and are more common/cheaper.. IF you have enough gear/torque to pull a 28"..
Old 03-28-2013, 10:11 PM
lance m p
lance m p's Avatar
Default Oh yes got more than enough..........>
to pull those, I was going to try either the Nitto's or the M/T's Drag Rad's as soon as I wear the BFG out won't be long. Waiting on the weather here in sunny cold a## Ohio. 3.42's, built 2004R @ 26lbs of boost.
Old 03-28-2013, 10:38 PM
larrywalk
larrywalk's Avatar
MT ET Streets 275-50-R15s work for me - mid 11s.
Old 03-29-2013, 08:21 AM
ajrothm
ajrothm's Avatar
I would try the 275/60/15 MT ET Street Radial PROs... Those are the hot tire out now... Once again, if you have enough get to pull em...
Old 03-29-2013, 03:20 PM
lance m p
lance m p's Avatar
Default Yep I think I'll try those...............>
Micky T's ET streets, I've been hearing good thing about those new M/T's instead of the Nittos.
To Drag Radials for a 1978
Quick Reply: Drag Radials for a 1978
