Parking brake adjustment procedure.
Having just replaced all the brakes on the rear Im struggling with the parking brake adjustment.
With the wheels off the car, I have it set so that from locked up ( turning by hand, just the rotor ) with the adjuster, I back it off about 8 clicks.
I then climbed under the car and adjusted the cable till there was no slack and it appeared to just start pulling on the parking brake mechanism.
Wheels back on and the brake isnt even beginning to hold.
Im concerned that the rear cable has jumped out of one of the levers at the rear. It did this once whilst adjusting the cable the 1st time. However, there did seem even pressure whilst pulling the parking brake all the way up.
What do you guys do when you replace the parking brake assemblies?
EDIT. Just watched a youtube vid and the guy adjusted the shoes, then pulled on the cable a few times and the rotor was free again! Adjusted up some more and he was good to go. Was this my mistake, to assume shoes were centered in the drum section?
TIA.
TIA.
My problem is a little unique. With a carb-ed engine the engine will usually bog down or stall in gear with the e-brake on when the clutch is released. With the LS1 the ECU senses a drop in RPM and revs the engine to compensate, overpowering the e-brake.
If I'm allowed to control the car I put it into 3rd gear instead of 1st (same forward movement on the T56) and I can get the engine to stall and the inspector is happy.
Rick B.
Should have posted back. The cable had jumped out of the parking brake lever on the passenger side again. What a pita. Not sure if it's the cheap cable or the cheap parking hardware.
Managed to get the adjustment done but should have replaced the front cable at the same time as the adjuster is near it's furthest point.
As soon as I get the engine running properly I will get out and test them.
