68 door removal
Received 1,469 Likes
Cruise-In II Veteran
My advice would be to paint the car with the doors in place.
There are two ways to remove the doors; with the hinges or without. Leaving the hinges on the car, the hinges unbolt inside each door. Removing the hinges with the door, the hinges unbolt from inside the car.
In either instance, index all the bolt heads and mark the shim stacks to assist with alignment when the doors go back on.
The AIM helps.
The AIM helps.
In process of painting my 68 now-took doors off also-removed access plates to hinges on doors and sprayed white paint on hinges to line up hinges when reassembling- no problem-reinstall will take 2 people though
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
