Oil Leak and/or Whats BBC Stock for a '71
Old 04-18-2013, 11:31 AM
72and86
72and86's Avatar
Default Oil Leak and/or Whats BBC Stock for a '71
I noted when I got the car and drained the oil it seems to have a 7qt pan. So...
After changing the oil last fall I noticed my 71 (454 BBC) starting leaking right at the drain plug. Several attempts the fix it and several types of replacement plugs later, it leaked all winter when in off site storage. It didnt leak alot but enough to be annoying and leave stains...
What was stock on this 454? A 4 or 7 Quart oil? Any ideas how to fix the leak? (it's believed that the pan might have a tiny dent next to the plug threads , not allowing the plug to perfectly sit up against the metal...)
If I replace it, do I go with a 4 or 7 qt? I'd rather not replace it, especially if its original...
Old 04-18-2013, 11:41 AM
MelWff
MelWff's Avatar
Received 1,816 Likes on 1,605 Posts
The stock pan would be 4 plus 1 for the filter, so you use 5 quarts at oil change. They make small metal washers with imbeded rubber on both sides. You screw them onto the plug and they prevent leaks. This gives you an idea what they look like and most autoparts stores should carry them.
http://www.maxautosupplies.com/produ...FUcOOgodAD8AgQ
Old 04-18-2013, 12:34 PM
72and86
72and86's Avatar
Yes I used that exact item from "oil-tite" brand. In fact when 1 didnt work we added a second which helped but didnt stop the leak. I stopped the leak for a while but later it began again.
Old 04-18-2013, 12:41 PM
calwldlife
calwldlife's Avatar
St. Jude Donor '22
I use thread sealer, non hardening
last threads before the head, allows no over tightening
and no loosening from vib
Old 04-18-2013, 02:42 PM
TimAT
TimAT's Avatar
GM Performance parts shows a 5 quart pan p/n 14091356 for the BB in '71. And a 6 quart pan 14104131, Also used on the LS-7. Maybe that's why my 69 takes 7 quarts? The sump is longer than normal.
Old 04-18-2013, 03:37 PM
LS4 PILOT
LS4 PILOT's Avatar
look at your owners Manuel. it gives the capacities in the back pages.
LS5 stock capacity should be same as my LS4 , my car takes 6 qt WITH A new filter change to complete an oil change.
Old 04-18-2013, 03:38 PM
MelWff
MelWff's Avatar
Default Washer
The washer you are using from "oil-tite", does it fit loosely on the oil drain plug threads or can you screw it on to the threads?
Old 04-19-2013, 12:55 AM
72and86
72and86's Avatar
Hmm. Dont remember...
Im not sure if the add'l oil capacity affects the oil pressure but when cold this 454ci pins the oil pressure gauge passed 70. As the oil thins it comes down to 30-35.
Old 04-19-2013, 07:45 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi,
The 71 GM Chassis Service Manual shows the capacity for the BB engines offered to be as Mel noted... 4 quarts in the pan, and 1 quart in the oil filter.
In fact it shows that capacity for ALL Chevrolet engines offered in 71.
The owner's manual lists 4 quarts plus 1 for the filter as the capacity on page 78.
Regards,
Alan
I can remember that back in the sixties I didn't have much money so would change the filter every other oil change. I can remember the fellow at the service station asking people if they wanted to change the filter or not.
Old 04-19-2013, 10:12 AM
72and86
72and86's Avatar
Originally Posted by Alan 71
Hi,
Regards,
Alan
I believe a "CAN" of oil was 0.39 cents in the early 70s...
To Oil Leak and/or Whats BBC Stock for a '71
Quick Reply: Oil Leak and/or Whats BBC Stock for a '71
