Radiator Install
Old 05-01-2013, 03:05 PM
billkat
billkat's Avatar
Default Radiator Install
I will be ordering an aluminum rad., rad. support, shroud , V crossmember and hardware soon for my 72 small block. I dont think it will be too difficult getting these parts installed since I have all the A arms out.
Any tips or advise that may help ?
Old 05-01-2013, 04:45 PM
Blue73Shark
Blue73Shark's Avatar
One good tip I learned on this forum is to cover the fins with cardboard during the install so that they do not get damaged.
Good luck.
Fran
Old 05-01-2013, 05:16 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi bk,
I'll second Fran's suggestion.
Good Luck!
Regards,
Alan
Old 05-02-2013, 03:18 PM
7t9l82
7t9l82's Avatar
i started doing that in the 70's. some laughed, but slowly every one i know started doing it. i was just protecting my hands, but figured out it helped in other ways too.
Old 05-02-2013, 03:28 PM
pauldana
Support Corvetteforum!
pauldana's Avatar
get a 3" HD DeWitts.... best information I could give ya..
Old 05-03-2013, 01:07 PM
donyue
donyue's Avatar
Hi billkat, I went with a Dewitts to fit in my 77. I ordered it with the dual Spal fans. The rad fit without any issues but the fan mounting had to be altered slightly as the edge of the fan assembly was interfering with the driver side A arm. Other than that slight adjustment everything is good! Very nice product!
Old 05-03-2013, 08:30 PM
Bob Heine
Bob Heine's Avatar
DeWitts is a great source for an aluminum radiator. Even if you are going with a mechanical fan, have them put the bung in for an electric fan temperature sensor. It goes right below the upper hose bib. I believe it's a no-charge option and you can just plug it if you don't need it.
They also go the extra mile if you have a special request. I made some braided lines for the transmission cooler and figured it would be nice to have a braided line from the radiator to the overflow tank. I used clamp covers but really didn't like the overflow tube on my original big block radiator. I asked them how much extra a -6 AN bung would be. They put it on with no extra charge.
Old 05-03-2013, 09:08 PM
JimT
JimT's Avatar
Three cheers for Dewitts!!!!
Old 05-05-2013, 01:36 AM
Bobs69BB
Bobs69BB's Avatar
If you need more room to get the shroud in, remove the upper bolts from the radiator support and pivot towards the front.
To Radiator Install
Quick Reply: Radiator Install
