SRIII project
SRIII project
Hi guys. I have been working on a SRIII chassis for my 1970. The running gear is done and just test fit the body on the car this weekend. It has a gen 1 small block 427 dynoed at 603 hp with a T56 magnum 6 speed and C4 suspension from a 93 ZR1 and coil overs in each corner. I have appreciate all the help and advise I have received from everyone on the forum and thought I would take the time to show the progress. I hope you enjoy.
http://s1233.photobucket.com/user/ve...ml?sort=3&o=13
http://s1233.photobucket.com/user/ve...tml?sort=3&o=7
http://s1233.photobucket.com/user/ht...ml?sort=3&o=10
http://s1233.photobucket.com/user/ve...tml?sort=3&o=9
http://s1233.photobucket.com/uhttp:/...ml?sort=3&o=12
That looks awesome. I have always wanted to do something similar to mine. Its going to be a blast when you get it done. Are you going to do AC? That is the one thing I wish I would have done with mine.
No I do not intend to do ac. This will be a road legal car but will see plenty of time on the road race tracks. I can always use my wife's 82 vette for trips that require ac. She is nice enough to allow me to driver hers too.
Terrorizing Orange Cones
IMHO, that is a perfect method to dispose of a pile of dead Presidents. That is one sexy looking beast that is being developed.
Thanks to Eddie 70 also, on posting the images so that we can all see the progress.
To the OP: what a beautiful example of great engineering. Keep up the fine work and thanks for sharing. You have new fans to cheer you on...
Thanks guys for all the input. I like the L88 style flares and intended to go that route at the beginning of the build. SRIII does offer narrowing the frame to keep the tires under the original 1/4's but I wanted the wider stance. Just my opinion.
Rob
The LS motor is a great motor, I just wanted to go somewhat old school on this one. There is talk around our house of doing a 58 vette for my wife after I finish this one and I would probably go with a LS in that case.
Great set up! Please post photos when the flares are installed. You may need an offset shifter for the T56. I have a similar motor and transmission in my 65 and an offset shifter was required for everything to line up properly.
I have just a couple little things to do before I lift the body off so I can spray the underside with sound deadener and then set the body for the final time. Once that is done, I can get it running and then install the roll bar or cage, haven't decided on which one yet. Any ideas or pics would be great of what others have done. At that point I will start on the body work. Mostly the fender flares and paint.
I will try to keep up with posting pics as the progress continues.
