Stingray Side Emblems Install
I removed the Stingray script side emblems (as well as all other trim) for a trip to the paint shop. The Stingray emblems are in good shape. One of the four pins was broken off long ago but the pin may be redundant with the adhesive. I plan to clean these up and reinstall them. There was a stringy black adhesive on the back of the emblems that easily came off with mineral spirits. The adhesive reminded me of weatherstrip adhesive. I notice that modern replacements have what looks like a foam adhesive die cut to match the script. Lacking the die cut foam adhesive, what would be the best way to duplicate the GM adhesive? I was thinking of using some black RTV Form-a-Gasket. The 3M weatherstrip may also work. Any ideas or experiences? Thanks.
Received 2,878 Likes
Hi7.....,
Originally there was the black die cut adhesive you may be seeing remnants of.
I believe there were no speed nuts used on 69-72 cars.
But, you could certainly use a couple on each script.
Regards,
Alan
Regards,
Alan
When I bought my '70 those emblems were not being held in place by anything. I guess previous owner didnt use anything after the paint job and they stayed in place just fine. I did get some speed nuts so they will go on soon.
I just put l82 emblems on my 74 could not find double sided tape so used a clear general glue from a parts store looks good no mess when u put it on u have to hold it in place for about 5 min so it grabs after that its on there really good
If I am remembering correctly, many moons ago on this forum someone posted the part number for a 3M double sided tape that was specifically for emblem reattachment. I have used 3M black weatherstrip adhesive on other cars in the past with good results.
DC
DC
As a matter of fact, I only found one speed nut. The other pins appeared to never have had them installed. Lots of options. Thanks everyone.
From my recollection those emblem 'stud's were secured by what the body shop industry called 'barrel nuts' They had nothing to do with a nut that would thread onto the stud but a 'sleeve' that was inserted into a drilled hole in the body then inserted to accomodate the stud as it was shoved into the sleeve. There were 'grip tips' that would prevent the emblem from working it's self away from the body.
We used many adhesives to secure emblems. I avoided the 'black goop' on the back of the emblem as for most cases it still looked like 'black goop' when the emblem was in place. The thin script of 'Cutlass' looked like hell.
We used 3M double sided adhesive tape and cut out around or in between the emblem letters. Very time consuming. 3M had a thinner clear tape to secure the emblem but it was quite thin to try to cut around.
I would suggest to go to what the AIM manual called for and duplicate.
Good luck.
Good luck.
I used a double sided tape from the home improvement store that is used to hold floor laminate down where 2 edges but together. I just stuck it to the emblem and use an exacto kinfe to trim to shape. I then stuck it to the car after pulling off the backing. It has been holding for over a year now with no problems
Whatever you use, it should be safe for the paint surface and it should also provide a 'cushion' so that the emblem does not vibrate against the paint and cause abrasion. You need to be able to remove that emblem and adhesive without damage to the paint.
I would highly recommend that you install at least 2 of the speed nuts on emblem pins to retain it securely. You don't need to tighten them too much...just enough to keep it snugged down. Those pins aren't very strong, anyway.
When I refurbished those 'script' side emblems, I found it IMPOSSIBLE to repaint them as the originals were (only the "background" section painted black). So, I chemically stripped the emblems, sprayed satin-black paint on all of it, then used an X-acto knife to peel off the semi-hardened paint from just the top surface of the lettering. They look a bit different than the originals....but I actually like them better!
just a testimony to the strength of silicone sealant. We use it in the machine shop where I work to seal the covers on fluid filled drive cases then tighten the bolts, and it takes a hammer and flange spreader to get those covers back off again a few years later.
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The thing about the script emblems is they usually trap dirt and wax and get really hard to clean around.
A thin "washer" cut from a piece of proper sized vacuum tube slid over the studs, and then speed nuts or a short length of vacuum tube over the studs once installed, allows for quick removal for clean-ups and keeps paint damage to a minimun.
But, respectfully I couldn't help notice that a couple of the "resourceful" solutions are probably going to end up back here as bona fide "Bubba's Bible" posts by their next care-takers... pass the the chisel, please.
Just say'n
