What are you guys using for a battery disconnect switch?
Old 06-06-2013, 08:37 PM
Iggycat2009
Iggycat2009's Avatar
Default What are you guys using for a battery disconnect switch?
Considering my 76 will be driven weekends/shows, the car will be sitting in the garage. I have a battery cut off on the negative side of the battery terminal but it's a nuisance to unscrew the plastic **** to disconnect with a side mounted connection - facing the back of the battery well.
Suggestions, what are you guys using?
Mike
Old 06-06-2013, 08:49 PM
Ontario73
Ontario73's Avatar
Nothing! My 73 sits for several weeks sometimes and always starts right up. Remember these were new cars at one time that people treated just like any other car. If it has a good battery it should be good for the whole winter!
Old 06-06-2013, 09:53 PM
MAXCO
MAXCO's Avatar
I was just thinking today about installing one. However I find I can leave my car for a few months and it will generally startup ok.
Old 06-06-2013, 09:56 PM
Mod75
Mod75's Avatar
Finalist 2021 C3 of the Year - Modified
Advance Auto has 4-5 different types to choose from
Old 06-06-2013, 09:58 PM
oldalaskaman
oldalaskaman's Avatar
a top post battery with the disconnect there, also went with a 'blade' cutoff. much easier to deal with when I need to leave the hood or doors open while I having 'corvette therapy'. my former girlfriend who did me the honor of marrying my old self last week , came up with that phrase. hope this helps.
Old 06-06-2013, 10:01 PM
gdh
gdh's Avatar
Congratulations and all the best to you both.
Old 06-06-2013, 10:42 PM
oldalaskaman
many thanks
Old 06-06-2013, 10:55 PM
riverracer au
riverracer au's Avatar
i used to have one on the battery itself
big pain opening the lid all the time to disconnect, especially when the lids n chairs are in the back
so,
i mounted one on top of the wheel arch, behind the seatbelt retractor.
all fits nicely under the '77 trim covers i have on the '72
drilled 4 holes, fed new wires down and the into the side of the box from the outside
now all i have to do is tilt seat foward, reach around to back of cover and insert the key
also put a ciggie lighter socket on the bracket, handy for the gopro on long runs
Old 06-06-2013, 11:18 PM
72LS1Vette
72LS1Vette's Avatar
I use a blade switch that I modified to go on the positive terminal. I need the ground connected so I can run a wire from the hot side of the blade to the LS1 ECM memory. I can see that it would be a pain to operate when the stowage are is full but I generally disconnect the battery when the car is emptied out and in the garage.
Rick B.
Old 06-07-2013, 12:13 AM
kwplot34
kwplot34's Avatar
I installed the battery brain gold 3 years ago. works great, comes with a FOB to connect and disconnect the battery.
here is a link.
http://www.summitracing.com/search/P...attery-Brains/
Old 06-07-2013, 12:17 AM
bmans vette
Support Corvetteforum!
bmans vette's Avatar
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Congratulations!
Bman
Old 06-07-2013, 02:13 AM
oldalaskaman
Originally Posted by bmans vette
Congratulations!
Bman
thankyou
Old 06-07-2013, 06:09 AM
worship79
worship79's Avatar
Congratz!
I use the hella key-type disconnect, mounted in de middle storage compartiment. That way I just have to reach behind me and turn to cut off all the power
Old 06-07-2013, 07:43 AM
Paul L
Paul L's Avatar
Wirth blade switch. The auxiliary wires are for a self-powered subwoofer.
Old 06-07-2013, 08:00 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Mike,
I have a side terminal battery and use the 'screw' type disconnect. There's enough room since the terminals face the rear of the battery box and the battery hold-downs position the battery toward the front of the box.
The disconnect means I need to re-set the clock but that gives me something to do while the engine warms up.
Peace of mind!
Regards,
Alan
Old 06-07-2013, 08:31 AM
jnb5101
jnb5101's Avatar
gee-whiz alan, your clock also works?!
Old 06-07-2013, 09:38 AM
resdoggie
Had a 1976 L-82, 4-sp
resdoggie's Avatar
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes on 925 Posts
Royal Canadian Navy
Nothing. I don't have a need for it. Battery Tender works great though through the winter.
To What are you guys using for a battery disconnect switch?
Quick Reply: What are you guys using for a battery disconnect switch?
