Chevy Brand Aluminum intake?
I found this on Ebay but it says LT1 so not sure it will clear the hood. Anyone?
http://www.ebay.com/itm/1971-1972-CORVETTE-LT1-CAMARO-Z28-3959594-ALUM-INTAKE-MANIFOLD-/140938774697?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d09b08a9&vxp=mtr
My '73 has a Holley 300-36 which is supposedly a clone of the LT1 intake. It's a pretty tall intake. I'm running a Holley Street Avenger carb with a 1.5" drop base air cleaner with 3" element and my air cleaner lid (billet, flat and 1/4" thick) just barely hits the inner portion of the hood in one spot near the edge of the lid. I really need to gain 1/8" to clear best. I have about 1/4" of clearance in the middle of the lid which has a nut that rises about 3/8" above the lid.
If I had an air cleaner lid that was thin at the edges but didn't rise more than 1/2" or so from the edge to the center, I would be in better shape. I'd love to have a big block hood.
Previous owner ran a 1.25" drop base with a 2" element but there had to be a very thick gasket on top of the carb to get the lid to clear the choke plate. I had about 3/4" of clearance all around with that setup but my current air cleaner flows much better.
All that said, remember that my '73 hood originally had a cowl induction setup and so may have different clearances than your hood.
DC
DC
2016 C3 of Year Finalist
Intake
I had that intake on my 69 350/350 and it did work with the stock hood, but just barely. You could see where the carb wingnut had scratched the inside finish of the hood. I was running a 670 CFM Holley Street Avenger on it with what I believe to be a stock LT-1 air cleaner.
Here are a couple of photos of Chevrolet's BowTie LT1 intake on my '69. Holley DP, stock air filter housing and filter element. It fits under the stock small block hood. It was a long time ago, so I forget the exact clearances, but I think I have about half inch clearance at the closest point between the hood and fir filter, measured with play dough. What I do not have is the half inch or so heat insulator that LT1s had under the carb.
Look closely under the rad hose and you can see the Winters Foundry snowflake.
And with the air filter installed:
I really like keeping my Corvette All Chevrolet.
Pete
Pete
DC
Pete
Pete
When I installed the ZZ4 in my '69 with the stock 3" tall air filter, I could see the small circular mark on the inside of the hood indicating the air cleaner was hitting. I just bought Puro # A60102 which is 2.5" high. It appears to now give me the clearance I need. The ZZ4 alum. intake is a medium rise as opposed to the low rise I had on my oem 350/300. I'm running the stock Q-jet with internal mods.
Photo is the 3" tall air filter
The "new" 2 1/2" filter
Unless you measure it, or know it ahead of time, you never notice the 1/2" difference of the #A60102.
If you a using a q-jet carb, why not use an aluminum L-82 Intake? You can pick them up really cheap and they are just as good as a performer intake
Received 1,469 Likes
Cruise-In II Veteran
If it gets tight between the hood and the air cleaner, the stock L88 and LT-1 air cleaner base is probably the lowest available on the market.
If it get to tight on your carb you may have to mill away the choke tower to allow for proper airflow to the primary's.
Wing nut? Chose a proper length (cut if you have to) countersunk allen key (hex inside) bolt.
I did both on my engine and it works fine with the air cleaner lid touching the vent-pipes.
//Ricky.
//Ricky.
//Ricky.
//Ricky.
