1978 steering wheel snap ring help
Do you have a plate depressor tool? that is the easiest way that I know to reinstall the snap ring. Just depress the plate and slide the ring over the shaft until it snaps in place.
In order to use the special tool (I call it a lock plate compressor) you also need to lock the upper steering shaft from telescoping. Usually tightening the star screw locks the upper and yoke shafts from telescoping.
However, the special tool usually interferes with the star screw. So you want a small set screw with a 5/16-18 UNC thread or a #20 Allen screw to replace the star screw. Tighten the set screw and the two shafts won't telescope. Then the special tool will work correctly.
Jim
Jim
Diy
The compressor tool is the right way to do it. My local Auto Zone doesn't carry it. On my column there is an empty ~1/2" hole at the 2 o'clock position. I was able to use a screwdriver through this hole to compress the spring enough to get the clip on.
