HELP, Replacing rear strut rods.
I am trying to replace rear strut rods but the lower shock bracket that holds the shock and rod is frozen solid. I've tried everything but cutting it with a saws all and I don't have a torch. Will a saws all work to cut the shock bracket?? Anyone have the same problem replacing yours?
I've taken two sets apart with little difficulty. I took the crown nut off and turned it around so that the solid end was flush with the threaded end of the mount. A couple of hits with a hammer and it popped right out. There is also a special "nut" made specifically for that purpose. It is a longer solid nut that threads onto the mount to give a more solid surface to beat on if your mounts are stubborn.
Remove rear lower shock mount
I bought the tool the screws on and they came out very easy with a 12 ounce hammer
The tool did not work for me. I cut them with an air cut off tool, saw will probably work too.
Post # 64:
http://forums.corvetteforum.com/c3-g...project-4.html
Post # 64:
I ended up cutting the end of my rods to get them off. I used a cut off wheel outlined in this link. I cut mine while on the car.
http://forums.corvetteforum.com/c3-t...ock-mount.html
what i have done is weld a flange nut to a sacrificial impact socket. liberally spray shaft with pb blaster then wind the socket/nut onto the shaft leaving about a 1/8" gap. bash with the hammer and back off the socket with each movement of the shaft. keep repeating till she comes out.
NE Events Coordinator
Same here on both sides. http://forums.corvetteforum.com/c3-t...ock-mount.html
