Fuel injection under a stock 73 hood?
Old 08-05-2013, 06:39 PM
Franks73
Franks73's Avatar
Default Fuel injection under a stock 73 hood?
Anyone install a fuel injection that fits under the 73 stock hood that they like? Will be going on a 383 stroker. Still not sure if I will go spread bore carb, or FI. Appreciate any experience, thanks guys.
Old 08-05-2013, 08:09 PM
DC3
DC3's Avatar
I plan to add EFI to my '73 at some point. I described my current setup on your intake clearance thread. I think any throttle body system will fit if matched up with an appropriate intake. I was told by a salesman that the FAST multi-port system will fit but I never double checked the measurements.
I'm thinking of using a FAST control system with the Edelbrock Pro Flo XT intake
I took some measurements last year and I believe this intake will clear although I'll need to verify the throttle body and linkage.
DC
Old 08-05-2013, 11:24 PM
Franks73
Franks73's Avatar
Thanks for responding. So much more involved. Fuel supply, fuel tank, computer box. Worth doing?
Old 08-06-2013, 09:17 AM
aussiejohn
aussiejohn's Avatar
Default 682xlr8
Fraank,
Look up Forum member Randy's LT1 swap. He goes by the handle of 682XLR8 and will probably chime in if he's looking here.
Regards from Down Under.
aussiejohn
Old 08-06-2013, 10:41 AM
682XLR8
682XLR8's Avatar
Originally Posted by aussiejohn
Fraank,
aussiejohn
Yep, that would be me
Not running the LT1 intake anymore, I am currently using a TPIS Miniram intake along with the FAST EZ EFI....pros and cons to using EFI, but I'm glad I went this route and would do it again. Many here on the Forum are using the FAST system as well as other systems, so if you have any questions just ask
Old 08-06-2013, 10:49 AM
fleming23
fleming23's Avatar
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
^^^^^What intake/filter set up is that?
Old 08-06-2013, 10:58 AM
682XLR8
682XLR8's Avatar
The filter is a K&N, the air intake I made myself.
I keep saying I'm gonna do a write-up on it, but have had too much going on and no time to be able to sit down and concentrate on doing a good legible write-up...guess I need to MAKE time
Old 08-06-2013, 02:13 PM
DC3
DC3's Avatar
From a fuel mileage and/or horsepower standpoint, probably not worth doing given the cost. A well tuned carb is a pretty good bang for the buck.
But I think its worth it from a drive-ability standpoint. Better cold starts, better throttle response, can fine tune throughout the rpm range, lower emissions, no gas smell in the garage. If I pick up some fuel efficiency, that's a bonus.
It's also worth it to me from an experience standpoint. I get to learn something new while enjoying my hobby.
DC
Old 08-06-2013, 02:20 PM
Marlin
Marlin's Avatar
Yea I'm going to go multi-port at sometime and run a microsquirt.
If you want simple then buy a full F/I kit.
If you want cheap get a Big block TBI unit and a Microsquirt to control it. You can get a plate to make the GM TBI bolt to any Carb intake manifold.
Old 08-16-2013, 08:24 PM
Kacyc3
Kacyc3's Avatar
I used a Holley commander 950 set up on mycar with a TBI and a carb manifold, so If the hood clearance is the same between 73 and 79 you can do like I did.
Old 08-16-2013, 10:07 PM
Franks73
Franks73's Avatar
Thanks for the input guys! Anyone else, still uncertain between carb, and F.I..Hate this indecision! Want to do it right the first time. What about the fuel pumo in the gas tank?
To Fuel injection under a stock 73 hood?
Quick Reply: Fuel injection under a stock 73 hood?
